I've been trying to use the spur gear script to create gears. When I use the default settings the gear is generated correctly.
But when I try my custom gear settings it crashes whole program.
I'm trying to create a 0.8 mod gear.
When I use these settings it works(though this isn't the size I want)
Standard: Metric
Pressure angle: 20 degrees
Module: 0.8
No. Teeth: 24
Backlash: 0
Root Fillet Radius: 0.4
Gear thickness: 10
Hole diameter: 0
If I reduce the no. of teeth to 12 it works as well.(I tried a few lower number of teeth values as well 10,21 and both worked)
When I increased the number of teeth to 30 it crashes. I just tried incrementally increasing teeth, 25 works but 26 crashes.
Is there something inherently wrong with my settings ? I tried using both versions of the script and both crash when I try 26 teeth or higher(other values I've tried include 60 and 84)
Using fusion360 v2.0.4095 on Mac OS X 10.12
Thanks.
