Spline no extruye
Spline no extruye
danielsr_1997
Observer Observer
Spline no extruye
danielsr_1997
Observer
Observer
does not extrude completely if I do it in pieces it confuses them and extrudes something that does not select
jhackney1972
Please attach your model for sketch diagnostics.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
danielsr_1997
Observer
Observer
I already attached it.
g-andresen
Unfortunately, the sketch is very awkward. That's why I got only 1 element for the extrusion.
In the second part of the screeencast you can see that the curve has many errors.
I recommend to use arcs or 3-circles instead of splines.
günther
g-andresen
just try it this way
günther
