spline adjustment in 3d sketch
Message 1 of 11
I cannot adjust my spline curves in a 3d sketch.  The handles don't work in fit point and the control points don't control.  Julia with AD said that the control points should work but the fit point doesn't. I tried the control point spline and the cotrol points are dead. Is ths for real? I can't control curves in a 3d sketch. I feel foolish for asking this.
Replies (10)
Message 2 of 11
jeff_strater
you have to use the Move command to adjust geometry in 3D splines - fit points, control points, or tangent handles.  Drag will not work in 3D.  Can you share your design here?
Jeff Strater
Engineering Director
Message 3 of 11
jhackney1972
I do not see an issue with either type of Spline in a 3D sketch.  I can move the fit points, adjust the handles of a fit point spline easily.  I can also move the control points of a control point spline.  Take a look at the Screencast, if I am not understanding your issue. let me know.
45d0f9aa-aed4-4c6d-934c-ab8565811f28,640,650
John Hackney, Retired
Message 4 of 11
I can't get either the handles or control points  (not here now) to work. I also can't select items to mirror.  I will  try move
Message 5 of 11
don't know how to share the file
Message 6 of 11
jeff_strater
this article:  How-to-share-a-Fusion-360-design will show you how to share a design with us.
Sketch Mirror also does not work on 3D sketch geometry.  Anyway, I don't recommend sketch mirror - model half of the boat, and do the mirror in the solid or surface toolset.
Jeff Strater
Message 7 of 11
here are screenshots
Message 8 of 11
the handles don't move, the control points (not there now) don't move. https://a360.co/3d8QHrk
Message 9 of 11
TrippyLighting
I can move the spline control point in that design with eh move command.
However, I've done a lot of surfacing in Fusion 360 and I don't think I'd create the curves for a boat all in one 3D sketch as that is difficult to manage.
Looking at the curvature there are probably too many spline control pints in that curve already.
Message 10 of 11
jeff_strater
here is a screencast showing how to move 3D spline handles using the Move command:
Jeff Strater
Message 11 of 11
That worked! Thanks for the help.
