Specific Fusion 360 drawing file will not open anymore
polesen88
polesen88
The 43 sheet drawing that I've spent weeks working on will no longer open. I closed Fusion and turned my computer off normally and when I try to open the file now it will not open. I've tried clearing the Fusion cache and reinstalling the GPU driver but the issue persists. Fusion CAD modeling works fine and I can open other drawings without issue. Also, I've tried opening older versions of the file and run into the same problem. Diagnostic logs attached.
Pramod.kadam
Hi @polesen88 ,
Sorry to hear that you are facing an issue. Could you please share the drawing (F3Z) file with us? (Or you can directly send it to [email protected]).
Pramod Kadam
Product Owner
Fusion 360 Drawings
polesen88
Hi Pramod,
The file has been sent to the email you provided.
nemadec
Hey @polesen88
We tried to open the file which you shared, We haven't encounter any issue  or crash while opening the file.
please refer attached snapshot.
Can you try one more time by uploading f3z which you shared and open drawing.
Regards
Chandrashekhar Nemade
Sr. SQA Engineer
polesen88
Hey @nemadec @Pramod.kadam
I tried opening the f3z file that I shared with you and ran into the same issue. Error report and diagnostic log file attached.
polesen88
I was able to get the drawing to open, however, I had to delete and then reinstall Fusion 360. It's not clear to me why this needed to happen but nonetheless, the drawing is working again. Thanks for your help.
