Spacemouse unhandled exception when changing speed
Hardy_RnD
Hardy_RnD
Hi, I'm getting the following message when I try to adjust the speed for my wireless spacemouse (3D connexion). See attachment.   I've also attached the report details.
Be good to find a solution because my spacemouse setting to too fast and I can not change it to a slower setting.
Thanks for reading
I would also add that, all other software that uses the spacemouse, works OK - no issues with changing speed
Phil.E
This looks like a problem with old 3Dconnexion drivers. Can you update your drivers and try again?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Hardy_RnD
Hi Phil,
Thanks for the reply.
Yes, I had the latest drivers installed
However, since F360 updated itself this morning (2.0.11680) this issue has gone away
Phil.E
Thanks for the update. Let me know if you encounter this again please.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
