Hi all,
I just started having this issue in which every time I create a sketch, my SpaceMouse reverts all axes to their default actions. This happens when creating new sketches and when editing existing sketches. When I Finish Sketch, the axes return to the settings I have set for them.
My specifics:
- MacBook Pro M2 Max
- 3DxWare 10
- 3DxMacCore version 1.3.7.529 (529)
- 3DxWare version 10.8.7 (3836)
- SpaceMouse Pro Wireless Firmware 0.00 (not sure why 0.00)
- Fusion 2606.1.36 arm64 [native]
What I've done/tried:
- Checked for updates (MacBook, Fusion, and SpaceMouse)
- Restarted everything (MacBook, Fusion, 3DConnexionHelper)
- Reverted to Legacy SpaceMouse Driver in Fusion (behavior continues)
- Reverting the SpaceMouse to Default settings
- Deleted and reinstalled SpaceMouse software/drivers and Fusion
- Tried with and without Lock Horizon and Lock to Sketch plane checked in SpaceMouse Navigation tab
- Using the SpaceMouse with USB cable instead of wirelessly
- Searching the forums for possible solutions
Hopefully someone has an answer since this is causing me much frustration. I've had to resort to not using my SpaceMouse when sketching because after years of muscle memory, it's impossible to revert to whatever the default axes setting are. Thanks in advance for any solution or help.
Cheers!
