Space Mouse Wireless Not Working only for Fusion360
castleworksmotorsports
Message 1 of 9
I have a Space Mouse Wireless, it works when using AutoCad and Siemens NX....but only the Zoom is working when I use it for Fusion 360.
Opening the 3DConnexion Settings, things are set to default.
Is there something in Fusion 360 I need to change?
Replies (8)
Message 2 of 9
karina.harper
Autodesk Support
Autodesk Support
@castleworksmotorsports
There shouldn't be. What OS are you on? What navigation style in Fusion?
Cheers,
Karina
Message 3 of 9
I am using Windows 10 and the Online version of Fusion. I'm not sure how to answer the navigation style...I have always used the default environment.
Message 4 of 9
sutherland-
Are you sure that your Space Mouse drivers are up to date?
Also, try just deleting the 3Dconnexion software and reinstalling it.
I encounter the same issue when working in F360 for a long time. Then I fix it by plugging the mouse with the wire, exiting F360 and  then joining back. Sometimes 3Dconnexion app does not recognize the F360 panel.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 5 of 9
TheCADWhisperer
Can you post screen shot (Shift Win S and Ctrl v to paste in reply) similar to this?
Message 6 of 9
It acts as though it does not recognize Fusion 360 on this machine.
Message 7 of 9
TheCADWhisperer
You are showing the settings for Chrome.
You need to click on Fusion (with that window on a separate monitor or bring it back to the front after clicking on Fusion...
Message 8 of 9
I am using Fusion.Online  (being run from Chrome). I am not using the Cloud based version.  Bringing it to the front while in Fusion, shows the settings for Chrome.
Message 9 of 9
TheCADWhisperer
Somehow I missed this important information in your original problem description.
