Some archived Projects not listed
karlpeet
karlpeet
On the my team Fusion 360 web homepage (myhub.autodesk360.com) under the archived tab all projects from Feb 2020 are not listed.
I can get at the projects from the Fusion 360 web homepage by selecting logo->admin->projects.
Well I can when the Admin option is shown.
How do I get all my archived files to be listed under the archived tab on the home page?
Karl
sasikanth.kollipara
Hi, Thanks for using Fusion.
Could you please elaborate on the discrepancy you are facing? Ideally, there should be no difference in the Projects listing in web and Fusion 360.
Click for the right one here as shown in the screenshot.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sasi
 Sasikanth Kollipara
 Sr. Quality Engineer in Fusion
LinkedIn
karlpeet
Problem solved - there was no real problem.
Issue was that on my Fusion 360 web page when I scrolled down the list of archived projects no projects from the last 2 years were displayed.  The solution was to do nothing; after several seconds another set of archived projects appeared; this needed to be repeated (scrolling to the bottom) several times until all archived projects were displayed.
sasikanth.kollipara
Good that the problem is solved for you. Please click on Like on the reply as this would help others viewing for a similar problem.
Sasi
 Sasikanth Kollipara
LinkedIn
