Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Solid Model Appearance Lost
johankx
johankx
Hi
I created a model for a few items and gave them appearances which worked fine, but when I opened it today. Some appearances were lost. I had a pine appearance that does not want to be assigned again to my model. You will see below that it is applied, but does not appear as per the chosen pine appearance.
I am a newbie so it may be something basic.
jeff_strater
I don't see any attachments here.  However, an image will not do any good to help debug the problem.  Please share your design here, so we can look at the actual data.  Thanks.
Jeff Strater
Engineering Director
johankx
Hi Not sure how to share this with you.
But seems like only the pine does not want to assign to the solid.
See if the link below you can access.
jeff_strater
There appears to be an appearance override put on the root component that is overriding the pine appearance.  If I remove that, the appearance shows correctly.
Jeff Strater
johankx
Thanks Jeff.
