Software freeze
Software freeze
1185196851
Software freeze
1185196851
Community Visitor
Community Visitor
fusion360 is a very easy-to-use software, but it is too stuck. Every time the software is started or closed, the software will be unresponsive for a long time. The software is installed in the solid state drive, but it is much slower than other similar software (such as SOLIDWORKS, 3Dsmax).And I found that when I created a new file for design, it was not stuck, but when I opened a part of the model that I designed last time, it was stuck. Whenever the software freezes, I open the task manager, but I find that the CPU, memory, and hard disk occupancy rates are very low, and other software I run at the same time will not freeze, which means this is not my computer The hardware reason.
TheCADWhisperer
Can you File>Export your *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
MoshiurRashid
Hello
Thanks for posting. Here I can suggest you 2 things.
1. Run as administrator Fusion 360. (reduces many steps to require permission while starting up)
2. Check your network setting if that is comfortable for fusion 360 or not.
3. If your graphics hardware is not performing well with the software, try optimizing the graphics performance.
Here is how
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
