so my dimensions were wrong
Message 1 of 13
so i am at the final step of my design and i did not leave enough space on the right hand side next to the z as you can see when i offset the offset is outside the main base anyway to fix this???
pleaseeeeeeeee don't tell me that i have to start from scratch if so then ill pull my hair out.
Replies (12)
Message 2 of 13
seth.madore
What would you like to do, make the stock larger, or move all the features over inside the stock?
Seth Madore
Message 3 of 13
seth.madore
Couple of comment, if you're open to some feedback?
1) You don't need to put each letter on it's own sketch, this could have all been done as one sketch, it would make it easier to modify in this case
2) you have some lost references, take care to keep these to a minimum:
Seth Madore
Message 4 of 13
either one is fine but they have all been extruded already so i don't know if it is possible
Message 5 of 13
TheCADWhisperer
I recommend that you start over from scratch using what was learned from this attempt.
Fully define your sketches.
Message 6 of 13
ya that sounds good i will learn from my mistakes this way
Message 7 of 13
seth.madore
Yes, fully define sketches, but I wouldn't necessarily insist that they start over. Consider this a learning moment and gain some experience from this mistake. Go to each sketch and just edit the position of the entities, adding proper constraints. The end goal is to have EVERY sketch entity turned black. Anything blue indicates that it's lacking constraints.
Seth Madore
Message 8 of 13
the issue is that there are a lot of lines and curves i have to project so if i do it separately i can make sure that i don't miss any
Message 9 of 13
alright since i did it once i should be faster in it anyway
Message 10 of 13
TheCADWhisperer
I have already started over for you.
Note that all is symmetrical.
Message 11 of 13
TheCADWhisperer
@Anonymous wrote:
...pleaseeeeeeeee don't tell me that i have to start from scratch if so then ill pull my hair out.
@Anonymous
You don't have to start from scratch - because I did it for you (see Attached).
Message 12 of 13
thanks a lot this helped but i now have the issue where i don't have the metric thread type i need to get 4mm as that's my screw size.
Message 13 of 13
ok so i just finished it is it possible for you to add screw holes for the motherboard and give me?
