Small CAM inch bug
Small CAM inch bug
leighCB8FK
Small CAM inch bug
leighCB8FK
In CAD / Model you can use " symbol or 'in' in dimensions regardless if your in mm or inches, and the software will add the correct value based on your preferences,
But in CAM you can only use 'in' and not the " symbol when inputting sizes, in the UK we mainly now work in mm but a lot of stock comes in inches, so its nice to add stock size in inches, and " is a lot more common use in the UK than using "in" as said this does work fine in CAD just not in CAM
Hope this makes sense.
Leigh
masa.minohara
Hi @leighCB8FK,
Thank you for posting! I may be missing the point but you can change the unit in CAM environment. Please see the screencast below.
Is this what you are trying to do? If not, could you record a screencast or attach some screenshots?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
leighCB8FK
ok let try and explain again.
I want to mainly use mm so have my preferences set to mm.
But now and then you have a project where some dimensions are given in inches.
In model you can enter dimensions as default mm but if you specify say '2 "' or '2 in' as 1st photo, your software will convert this to 50.80 mm which is correct and showing in the 2nd photo.
but if your in CAM, and do the same thing in the stock size box, it does not work.
this is does cause a slow down of flow esp as in the UK a lot of stock still comes in inches.
hope this makes sense
Leigh
as you can see in Model you can use '"'as you can see in Model you can use '"'but you see it does not work in CAMbut you see it does not work in CAM
masa.minohara
Hi @leighCB8FK,
Thank you for the clarification! Sorry, I totally missed what you were saying...
I have logged this with the development team for further investigation. (the ticket ID is CAM-9668 just for your reference)
Thank you for reporting the issue!
Masanobu Minohara
