This particular Brand of 3D Printer does not specifically show up in the Fusion 360 Post Processor library search. Most likely either it emulates another common printer or a standard machine language. For example, my 3-Axis Router Table is an off brand but it operates on GRBL processor commands so a standard GRBL post processor will take the Fusion 360 milling toolpaths and create the G-Code needed by the router.
If you go the the website from your printer, you will find the instructions you need to take your STL file into G-Code. It would seem that within the installation package you received with your printer, Kisslicer is included and this will be used to create the required G-Code.
John Hackney, Retired
