Sketch/model view visual distortion
I'm working on an imported Sketchup model by drawing new sketches using the sketchup meshes as visual references. I first noticed that sketch dimension text looked distorted, something like 125% normal vertical height (stretched vertically). I then noticed that a centerpoint circle was obviously being distorted into an ellipse (taller than it was wide). Everything internally appears to be accurate, i.e. the sketch when exported as a DXF and opened in DraftSight is accurately shown as a circle. Below is a screengrab with a red circle added in an image editor. This has persisted through a repair and a few restarts of the machine. The screenshot has the sketch plane viewed straight on, and it's parallel to one of the normal planes. Camera view is set to orthographic. What else can I try to fix this? As I'm basically tracing elements by eye to start with, it would be helpful if they were displayed correctly.
Visual sketch distortion
