Sketch massive bugs
Sketch massive bugs
adesk-tom34
Sketch massive bugs
adesk-tom34
with latest build (2024-November 21), the sketch functionality is totally broken, especially for simple 'line'-Offsets. See in attached F3D file, the sketch named 'HORROR' was just created with simple offset and a rectangle aligned with 'Colinear', then mirrored. the sketch is fully constrained (Sketch.ShowUnderconstrained = OK), yet I can grab&drag the right-side line (see image,  solid-blue line) outwards, separating the colinear lines! (and sketch even stays fully-constrained!)
see result screen:
IMHO this build is rotten and should be recalled.
g-andresen
therefore the display in the browser is also incorrect
maybe @Phil.E  can say something
2. I would do it without symmetry
(view in My Videos)
günther
adesk-tom34
hi günther, note this is a artificial design I made just trying to reproduce one of the bugs. Of course I know this one geometry can be done using other/better steps, like you showed. but that's not the point here.
TrippyLighting
Two things.
1. That is certainly a bug.
2. That is also certainly an incredibly convoluted way to create such a simple sketch. Your sketch has 26 elements, my sketch only has 15 and contains the same information
g-andresen
From my point of view, the behavior is caused by superimposed lines and unfavorable assignment of dimensions and missing coincidences.
The horizontal line (7mm) is linked to the superimposed & independent vertical construction line, but not to the construction line dimensioned at 23 mm.
The mirroring was carried out on the dimensioned line.
However, the question remains as to how colinearity is destroyed.
(view in My Videos)
günther
sameer_babarNJS6C
We have created ticket FUS-179136 for the issue where colinearity is getting destroyed.
Our team will analyse it further more and will provide a fix.
Sameer Babar.
Autodesk Fusion Team
