Sketch is black showing fully constrained but won't lock
rogermbown
Message 1 of 14
rogermbown
I'm a little confused. I have a sketch that shows as fully constrained (all lines are black), but won't lock. I have extruded and the software lets me fillet the complete top edge but only partially the bottom.
Any advise please
Replies (13)
Message 2 of 14
TheCADWhisperer
Message 3 of 14
rogermbown
File is attached, Thank you.
It is the bottom edge of the Body that won't allow the fillet, although it allowed the entire top edge to fillet (it was extrude from the zero on the plane so don't quite understand why it would allow one edge but not the other? Some of the edges have fillet on the bottom but not the larger one)
On the "not locking" I have checked the geometry and all seems to be OK, but I'm still a rookie, so I'm sure this is something small and a learning curve.
Message 4 of 14
g-andresen
File  missing, try again
günther
Message 5 of 14
rogermbown
Should be attached now?
Message 6 of 14
TheCADWhisperer
Do you actually see it attached?
Must Reply using the web forum, not by email.
Message 7 of 14
rogermbown
Yes, it showed as attached in both mails. Let me try a different browser
Message 8 of 14
TheCADWhisperer
I don't believe it.  Show screen capture image here...
https://forums.autodesk.com/t5/forums/replypage/board-id/962/message-id/120827
Message 9 of 14
rogermbown
Sorry, my fault, I was replying direct on email not via the forum.
Should be attached now.
Message 10 of 14
TheCADWhisperer
Sketch1 has an extraneous construction lines and several dimensions that cannot be measured in the real world.
Did you intend Tangency here?
and here...
and here?
Message 11 of 14
rogermbown
Hi, Thank you
One the first 3 points - No I did not intend a tangency, I drew a circle to intersect the end points of the 12mm straight lines and then trimmed the part of the circle that is not wanted
On the 4th point. No I did not intend a tangency. I drew a construction line to the circle diameter and then drew a 3 point arc from that point with the idea to fillet the intersection to create a smooth flow
Message 12 of 14
TheCADWhisperer
Examine my sketch.
You will have to remove the Tangencies that I assumed.
Message 13 of 14
rogermbown
Ok Understand now, thank you. I will apply to my original sketch
Message 14 of 14
rogermbown
Hi Your solution made sense and helped me understand the tangency issue, i thought I'd try for myself but was not successful. I though I'd make a simpler version without the 12mm straight line and only arcs intersecting one another. Again the sketch is fully black but does not lock. Can you advise why please
