Sketch Distance Dialog Box Cut Off - Bug?
mandicreally
mandicreally
Sometime this week Fusion started a really frustrating thing where a dialog box is cutting off the font inside of it.
When I go to draw in a Sketch the Dialog Box for Distance (length of a line, size of a polygon, radius of a circle, etc) cuts off the text. If I need to enter 62.50mm, I can only see the 2.50mm clearly and the 6 will be slightly cut off. (See attached screen grab.) Need to get a 300mm line? Good luck cause the 30 will be cut off and all you will see is 0.00mm. It is intensely frustrating and makes me have to double check every measurement to be sure I entered it properly by blindly typing.
When Extruding or doing other modeling functions the dialog box is fine, it is only in Sketches where the issue has popped up (that I've found).
Is this a settings issue or an update bug? I know Fusion updated some day this week and it just started to be a problem. Nothing about my computer changed otherwise and I haven't had a chance to test Fusion on another PC as I've been busy with a project I need to get done.
Fusion Version: 2603.1.15 x86_64
Windows Version: 10 22.h2 (build 19045.6093)
CPU: AMD Ryzen 9 5950X
GPU: Nvidia RTX3090Ti (June Professional Drivers)
asiudaisd
I also wish to see that issue fixed.
A similar issue is the bottom quarter of the text being covered with a white bar when not moused over.
(view in My Videos)
wout2305
Community Visitor
Community Visitor
Hey there,
I ran into the same issue, i think it has to do with the experimental themes.
When i unchecked this under profile > preferences > preview features > enable UI themes the problem was solved.
Hope this helps untill the bug is fixed
james1123
Community Visitor
Community Visitor
Same issue here, and your suggestion fixed it for me too thanks!
Was enjoying dark mode though, hope this is fixed soon....
