Sketch Dimensions - unable to display with a body behind it
I'm trying to add a dimension to the innermost circle in sketch3.
When you try to apply it, the UI is unable to display the dimension unless you hide the body behind it.
If you adjust the view you can see the dimension only if there is no part of the body behind it.
If you make the body completely invisible, it functions as expected.
Steps to reproduce:
Open the attached file
Edit sketch 3
Attempt to add a dimension to the circle as shown above.
The workaround is simple and I'm not stuck, but this may be a bug
