Sketch: Dimensions tab missing
dufner_dominik
Observer Observer
dufner_dominik
Observer
Observer
As usual, I am new to the software. I try to add a dimension between two dots, but it shall be the distance parallel to the X axis and not the default "shortest path" between those two dots.
I assume I need that extended "Dimensions Tab" which includes "Arrange Dimensions" and so on... as seen here on this help page: https://help.autodesk.com/view/fusion360/ENU/?guid=DWG-ARRANGE-DIMENSIONS
But where do I find this?
I
karina.harper
Autodesk Support
Autodesk Support
Hi @dufner_dominik
The 'dimensions' dropdown is actually a section in the Drawings environment.  There is not yet a command in the sketch environment that is similar to arrange/tidy up in Drawings.
karina.harper
Autodesk Support
Autodesk Support
@dufner_dominik
Sorry, I skipped the first part of your question. To get the right dimension 'direction', it will depend on where you move your cursor while you are assigning the dimension. Like this:
TheCADWhisperer
@dufner_dominik
I recommend that you attach your file for demonstration using your actual geometry as I see other issues as well.
g-andresen
Enter the  menu for the selection via right click
günther
