Project Link: https://a360.co/2ZXw9iA
This behavior is so screwy I don't even know how to describe it. Open up sketch 3 of Component 'Base'. Right in the middle is a dimension that says 14.768536. If you use the measurement tool, it says the two lines involved are, in fact, 14.768536 inches apart; however, if you hover over the dimension, it says it is dimension d108 and it has a value of 16 inches (which is what it is supposed to be). If you go to Modify->Change Parameters and look under sketch 3, it, too, thinks that d108 is 16 inches. Double clicking on the dimension and entering 16 doesn't get the sketch to change. Furthermore, when you double click on the dimension, it comes up saying it is 16 inches even though the item you double-clicked on said 14.768536.
The dimension right below it, d80, has the same behavior: it thinks it is 1 inch, but it says it is 3.306161, which is also what it measures.
What's worse is that I got these dimensions by accidentally grabbing the sketch someplace and dragging it, even though it was correctly dimensioned previously and the lines had turned black.
I tried closing the project, shutting down Fusion, restarting, and re-opening, but it didn't fix the behavior. I suppose I should try a reboot, but I really don't think that will help.
The little fingers of my left hand are very numb and I often type shift/ctrl/caps lock/Window/alt keys when I don't intend to (in addition to hitting ~/`, 1/!, or F1 when I mean Esc), so I probably typed something that confused the daylights out of Fusion, but, really, how Fusion could get so far off into crazy land so easily is less than fully impressive.
I suppose a massive corporate response is not needed. I'll probably just open a new project and start over from scratch. (The part I'm modeling is filled with odd-angled weirdness and the drawings I'm working from are incredibly confusing. This is already my fifth attempt, so what's one more.)
Respectfully,
Bill
