Sketch dimension move around, its annoying!
pusakaajisaka
Message 1 of 9
pusakaajisaka
After updating fusion 360 (and relaunch it), when sketching, the dimension moving around or jump in random places after selecting second point. Its software bug or just in my fusion 360?
Replies (8)
Message 2 of 9
g-andresen
This could be a case made for @Phil.E
günther
Message 3 of 9
Phil.E
Thanks for the report.
Are you using Fusion on a second monitor?
Are there any sketch related add-ins installed?
@g-andresen Thanks for the heads up.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 4 of 9
pusakaajisaka
I'm not using secondary monitor and third party plugin or add-in sketch. I ran fusion 360 in laptop.
thanks
Message 5 of 9
Phil.E
Can you please gather graphics information using the built in Fusion Graphics Diagnostic tool? Look on the Help menu, under Support and diagnostics.
Here is the location.
When the dialog opens, use copy to clipboard, and paste the results into a reply. Thanks in advance.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 6 of 9
pusakaajisaka
[GPU Information]
GPU Device: NVIDIA GeForce RTX 3050 Laptop GPU
GPU RAM: 3968 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 552.22
GPU Driver Date: 04/12/2024
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: On
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Message 7 of 9
rohit.bapat
Hello @pusakaajisaka
Can you please share the file with us so that we can debug and get to the bottom of this issue?
Rohit Bapat
Product Owner
Message 8 of 9
pusakaajisaka
Im sorry  Ican't share my file, because it is project from my office. But after updating, when creating new sketch, the dimension back to normal. sadly, when edit another sketch from  existing file, the dimension still move around 😞
Message 9 of 9
rohit.bapat
I can understand. If you wish you can share the data on my official email id rohit.bapat@autodesk.com Your data will be kept safe, secure and it will not be shared with anyone without your prior permission as per our data security policy.
Rohit Bapat
Product Owner
