Sketch a helix along a path
NichollsJMT
NichollsJMT
Dear Fusion 360, please can you sort out allowing being able to draw a helix along a path as this is a big deal.
Many thanks,
James
davebYYPCU
Coil Tool, or
Sweep with twist angle,
does not work for you?
NichollsJMT
Completely understand the coil tool but it is a fixed profile and only goes in a straight line.
Sorry I forgot to say the reason why I need to sketch a helix along a path is because the path is a wavy spline, meaning not straight.  I fairly sure you could do this in Onshape back in the day when using that.  Just surprised you can't do this in Fusion and am a bit stuck.
Thanks for your help tho.
HughesTooling
You can use a surface sweep with twist to create a helix along a curve. Use the edge of the surface for any further features, don't use project include 3d geometry in a sketch as that will be less accurate. See attached file for example.
Mark Hughes
Owner, Hughes Tooling
NichollsJMT
Thank you for this suggestion, I will defiantly give this a go.
Nice one.
NichollsJMT
It worked a treat 😎
Thank you very much for the very quick solution, top job 😀
