sheetmetal making two bodies in one component?
NoHandsNeeded
Message 1 of 15
NoHandsNeeded
hi everyone
i am trying to make 2 bodies in one component. do I have to make another component (I have tried but it kept going back to original ccompomnant)
Screenshot 2025-08-19 134914.jpgMAIN COMPONENT
. .  .   BODY I. WANT TO SEPARATE ----->
thanks so much in advance!
Shane
Replies (14)
Message 2 of 15
Warmingup1953
You can have two Sheet metal bodies in a Component, but only one flat pattern or unfold.
Message 3 of 15
HughesTooling
You should probably avoid creating sheet metal bodies in the main component and create components for each part. Have you started with one body then spit so you ended up with 2 bodies in one component?
A workaround to copy the body into a new component is use boundary fill to create the copy. So create a sheet metal component, use boundary fill to copy one of the bodies into the new component then use Convert to Sheet metal on the copy.
Here both bodies in the main component.
And here one body copied into its own component.
Sample file attached.
Mark Hughes
Owner, Hughes Tooling
Message 4 of 15
TheCADWhisperer
@NoHandsNeeded
Message 5 of 15
NoHandsNeeded
hi CADWHISPERER
here is my f3d file and a video of what i am trying to replicate 😁 i wanna show my brother i can CAD one and get it ready to fold up ::)
cheers
Shane
Message 6 of 15
TheCADWhisperer
@NoHandsNeeded
We will start by reviewing the basics of Sketching...
(view in My Videos)
Message 7 of 15
TheCADWhisperer
@NoHandsNeeded
If I understand your Design Intent - we would still need to add hinge feature (either as a separate component or bend a piano hinge into these two components with a wire component connecting them).
Not sure if you want the latches too.
Do you want the cut out "windows" in the moving lid component too?
Message 8 of 15
TheCADWhisperer
@NoHandsNeeded
Where did you go?
I had more suggestions for your design.
Message 9 of 15
NoHandsNeeded
sorry mate ;Im back
the changes you made are spot on and the piano hinge being folded into the design is brilliant!
I will want to add holes for the screen, is that just an extude cut? ,
on the sides for where tubes come out I want to make it more closed in and then do a cut out, is it best to extend this flange then do cut outs?
also can a clamp be folded or just make an extra tab for one?
Thank you so much
Shane
8
Message 10 of 15
NoHandsNeeded
Sorry @TheCADWhisperer I appreciate your solution but due to my condition I can't spend hours on the computer
apologizes
Shane
Message 11 of 15
TheCADWhisperer
@NoHandsNeeded
Attach your latest model here.
Message 12 of 15
NoHandsNeeded
Message 13 of 15
TheCADWhisperer
@NoHandsNeeded
I don't see any dimensions on your Sketch10?
Where did they go?
Message 14 of 15
NoHandsNeeded
Hey @TheCADWhisperer
yer I just threw in the sketches no measurements yet as i'm not finalized on sizes.
I thinking just put on bolt on hinges instead of piano hinge (much easier to replace)
can the sides judst o from bottom flange them i can cut what i need gone?
thanks again so much'
Shane
Message 15 of 15
TheCADWhisperer
@NoHandsNeeded
Communication is best carried out in the open forum rather than private message for the benefit of the community.
Blue lines and white dots in a sketch should keep you awake at night.
No red lock symbol indicates that the sketch is not fully defined.
Visually, we can probably assume the geometry is centered symmetrically - but we should not be making assumptions.
Underdefined geometry does not automatically adapt to edits and edits are almost always needed (unless you are perfect).
