Sheetmetal Bend Centerlines Disappearing When Increasing Bend Angle Past a Certain Point
BeginnerBrent
BeginnerBrent
I am designing a part that has a few bends and two flanges I want to add in the same feature so that the place where they intersect will automatically miter. When I have the bend angle at 38 degrees or less there are no issues and the bend centerlines stay in the flat pattern and are visible in the drawing. If I change the angle to 39 degrees of more (I want 50 degrees) the corner relief looks rounded and the centerlines disappear.
Is there something I can change with the corner relief in order to keep a larger angle? If I select the two edges in two separate features it will keep the centerlines as long as the two flanges do not intersect, but you do not get a very tight seam, which I want to weld solid in the final part I am making. Any help would be greatly appreciated! I have tried uploading two different screencasts MANY times and for some reason I cannot.
https://knowledge.autodesk.com/community/screencast/d1666ac7-7eb3-4d60-94b7-60cb69cb70ed
https://autode.sk/3GCnILM
mohammed.aliTDPXK
Hello @BeginnerBrent ,
Could you please attach you model as well?
I tried from scratch and was not note able reproduce from scratch.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
BeginnerBrent
Yes, I should have attached the model with the original forum post. Hopefully you can open the model ok.
mohammed.aliTDPXK
Thanks for the model, I can see the issue now with your model and this seems scenario specific, let me check with team and get back to you.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
