sheet Metal miter
sheet Metal miter
sheet Metal miter
  Trying to add a compound angle miter on this box.. The jpg is a model from solidworks.. I am trying to create the same thing in fusion but I am having difficulty. Need to fill the corner. is there a way to extend??
TheCADWhisperer
Can you Attach the original *.sldprt file here?
engineguy
@Anonymous
This of any use to you ??
Just used the "Draft" function to angle the ends the 4.5 Deg needed to be parallel as in the image, if it is of any use your file is attached with the modification needed, check the "History" for the actions.
Stay Safe
Regards
Rob
  Thank you, that fills the corner. What would be the trick on adding that other mitered flange at 92 degrees ?
Sorry sir, can't do that.. Legal issues.. Is there some information that I left out?
engineguy
@Anonymous
What 92 deg ?? Not on the file you uploaded ???
Stay Safe
Regards
Rob
