Sheet metal jog fillet
- Mute
- Permalink
- Report
Hello, I'd like to share an issue I was having:
Creating a jog with fillets in sheet metal results in unexpected behaviour.
To replicate.
With flange tool, create a flange from a sketch profile on XY plane.
With flange tool, create a perpendicular flange from edge of initial flange in Z axis.
Extrude cut edge of perpendicular flange from sketch profile on YZ plane.
Using one instance of fillet tool, fillet inside corners then outside corners larger than cut is deep.
Result: Sometimes the cut and fillets are centred to the extruded sketch, but changes asymmetrically when extrude sketch is changed. Sometimes its stable and never changes, Sometimes it's always asymmetric.
Expectation: fillet behaviour should be consistent, left to right.
