Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Sheet metal corners Linear weld - special flange with angle 140° - Relief Shape
stephane.olivier44
stephane.olivier44
Hi everyone,
I want to create a corner with a flange angled at 140°, but I can't manage to do it because I can't bend the flanges separately. I tried using a sketch on the flat pattern, but without success
best; Stéphane
Capture d’écran 2025-08-07 à 17.12.35.pngCapture d’écran 2025-08-07 à 17.12.35.pngCapture d’écran 2025-08-07 à 17.12.51.pngCapture d’écran 2025-08-07 à 17.12.51.pngCapture d’écran 2025-08-07 à 17.15.43.pngCapture d’écran 2025-08-07 à 17.15.43.png
TheCADWhisperer
@stephane.olivier44
stephane.olivier44
Hi every one,
please find the file exemple for corner weld relief shape,
best
Stéphane
HughesTooling
You can use Move-Rotate on the flange to change the angle.
See attached file.
Mark Hughes
Owner, Hughes Tooling
stephane.olivier44
Thank you very much, Mark. I didn’t know about this face tilt function — it’s amazing
