Shape issue
Shape issue
memo2022
Message 1 of 24
Shape issue
memo2022
Hey guys, how to change this oval shape lid into square and making it fit into the chamber size with four screws if it is ok to make video for that I really appreciate it. Please see the attachment.
Replies (23)
Message 21 of 24
memo2022
It was oval and I created a square shape for it and it becomes like that how to connect it well with square shape so it does not look like this. If you make a video on how to connect the oval shape with suqare shape this is how i learn. thanks
Message 22 of 24
TheCADWhisperer
@memo2022 wrote:
 If you make a video on how to connect the oval shape with square? shape this is how i learn. thanks
OK, let's get started.
Sketch the rectangle shown below...
Attach your new file here for next step.
Message 23 of 24
TheCADWhisperer
@memo2022
Where did you go?
Do you need a video on how to sketch a rectangle with dimensions?
I have been trying to help you master using dimensions for 4 months...
https://forums.autodesk.com/t5/fusion-360-support/how-to-create-tubes-inside-object-for-duffusion-of...
...but every time I mention using dimensions you disappear?
I have to get some other work done, I will check back later to see if you have made progress on sketching a rectangle with dimensions.
Message 24 of 24
memo2022
For the https://forums.autodesk.com/t5/fusion-360-support/how-to-create-tubes-inside-object-for-duffusion-of... i got it working thanks for your help. I submitted another question i hope you receive it here https://forums.autodesk.com/t5/fusion-360-support/erase-lines/m-p/12523525#M190819
i got the lid right but the chamber did not work??
