Shape issue
Shape issue
memo2022
Message 1 of 24
Shape issue
memo2022
Hey guys, how to change this oval shape lid into square and making it fit into the chamber size with four screws if it is ok to make video for that I really appreciate it. Please see the attachment.
Replies (23)
Message 2 of 24
davebYYPCU
No movie, just a new atart beginning of the timeline.
change as suits you.
Might help...
Message 3 of 24
memo2022
The O ring groove dimension is not correct. It has to be 52 ID and 62 OD please.
Message 4 of 24
davebYYPCU
Edit Sketch 3 double click the slot width dimension
Change the slot width from 2.5 to 5.
Might help...
Message 5 of 24
memo2022
Still not working please help me The dimension has to be 52 ID and 60 OD thanks
Message 6 of 24
davebYYPCU
Added the (60) 30mm dimension and made the radius (2mm) as a driven dimension.
Might help...
Message 7 of 24
memo2022
The dimensions are not correct the lid ID O ring groove is 52.091 and i want  52.00 mm and OD 59.909mm and i want 60mm
For the well O ring the issue is the same they are not exact.
I asked for the lid but i found they were changed
The  O ring groove needs to be 52mm ID and 60mm OD thanks
Message 8 of 24
TheCADWhisperer
@memo2022
Would you like to learn how to do this  yourself - step-by-step so that you do not have to depend on someone else to get it right?
Message 9 of 24
memo2022
make video about it please
Message 10 of 24
TheCADWhisperer
@memo2022
I will make still images with instructions.
You will follow my instructions exactly, step-by-step.
Check back in a moment for first step...
Message 11 of 24
TheCADWhisperer
@memo2022
Start a new file.\
Start a new sketch on the XZ plane.
Step 1. Sketch the rectangle below the origin and dimensioned as shown below...
Message 12 of 24
TheCADWhisperer
@memo2022
...now add the 40mm height dimension as shown below...
Now add a Midpoint constraint between the Origin and the centerpoint of the top vertical line....
Note that the sketch changes color...
(Your color might be different depending on your settings.)
The sketch is now fully defined...
Extrude the sketch midplane as shown below...
Attach your new file here for the next set of steps.
Message 13 of 24
memo2022
My issue is with O ring groove it has to be 52 ID and 60 OD mm
Message 14 of 24
davebYYPCU
Message 2 here was change as suits you.
Edit the sketch and make the slot centre line connect to the plate,
I left a small gap for squish.
Message 15 of 24
TheCADWhisperer
The issue is that you are not following my instructions.
I thought you wanted to learn how to do this yourself.
If you knew how to follow my instructions you would know how to edit your original file or the file that @davebYYPCU a did for you.
This part geometry is about as simple as it gets - Attach your attempt to follow my instructions here for next set of steps.
Message 16 of 24
memo2022
I fixed the issue and I want to erase the oval shape please see the file and the image in the attachement
Message 17 of 24
memo2022
can you help with that please
Message 18 of 24
davebYYPCU
I am confused - message 1
said,
change this oval shape lid into square and making it fit into the chamber size with four screws.
If I change the lid to the original shape, no room for 4 screws.
No need to change anything except the o ring position.
Message 19 of 24
memo2022
I have sort that out please help me with the question i have mentioned above
Message 20 of 24
TheCADWhisperer
@memo2022
Would you like to learn how to do this yourself with step-by-step instructions?
Why did you create a 0.00278184 step in your geometry?
How will you manufacture geometry that is 10.0089604?
Where is your history?
