Server verification warnig
hato54
Message 1 of 55
hato54
Suddenly I get this message : "Server Verification Warning, Unable to validate a security certificate"
I never had this problem before. Using Windows 7
Replies (54)
Message 41 of 55
laglanzer372
I uploaded log files. I am getting a server verification warning.
Message 42 of 55
bofggma
So, what way problem has solved? I have the same problem- can`t export to stl. After export proces - faile. Program note: "Server Verification Warning Unable to validate a security certificate. Many times this can be triggered by proxy servers, security software, or out of date OS patches. Please visit the "Network/Server Verification" preference page if you would like to change this setting."f360.JPG
Message 43 of 55
mroek
Did you try to go to that setting and change it to "Do not warn when accessing through an intermediate server", as shown here:
Message 44 of 55
bofggma
Yes. And I subscribed allready and even updated root certificates (cos i love Win 7) and enabled somthing in run cmd u know). And note: Server Verification Warning Unable to validate a security certificate..... gone, but export still doesn`t working(
Message 45 of 55
kindleegor
Observer
Observer
Yeah, same issue for me on Win7 for few days, nothing worked from what I tried.
Message 46 of 55
bofggma
To many troubles of win 10 for government agencies it stops working for days and weeks after new updates in in Ukraine. My win 7 helped me every time. And now I have troubles. Autodesk please find the new way for me with my stability win 7 and I give you a new slogan: "We work at a level of stability so you can keep breathing!"
Message 47 of 55
bainai144
Observer
Observer
I have same problem on WIN 7, i spent a day installing and trying many different things like hotfixes, windows updates and reg edits and nothing worked but i found another way to export .stl :
right click on a body
save as mesh
select format as stl  (binary or ascii)
set other options
save
i have not fully tested this method yet but it saves files as .stl which i can open with prusa slicer
Message 48 of 55
osman-pasha
I've started getting the same "Server certificate" warning after yesterday's server maintenance. No configuration changes on my side. I can choose to "Trust anyway" and continue working, so not a big deal, but still that needs fixing.
Using Win 10 x64 21H2.
Message 49 of 55
phunk80
MacOS 12.5
Same Problem starting after yesterdays maintenance.
Man, I´d rather pay for a working copy without getting more and more features added than all this trouble the SaaS approach causes ...
Message 50 of 55
l_kesiunas
Same problem for me too after maintenance. Please fix it
Message 51 of 55
tejchmanovam
same warning on my PC. I checked updates and even reinstalled Fusion, but that didn't help. Then I want through the logs and found a warning:
20221114T104700 W .15996 SSLVerifyPeer Warning calling: https://f360sc-p-ue1.api.cosv2-p-ue1-dn.autodesk.com/api/v1/sessions
It is caused by certificate, that was revoked a few days ago, see https://certificate.revocationcheck.com/f360sc-p-ue1.api.cosv2-p-ue1-dn.autodesk.com.
So Autodesk have to fix this on server side.
Message 52 of 55
RajkumarIlanchelian
Our apologies for this issue. We have made the changes on our side and this should not be showing up any longer. Thank you for your patience and escalating this on the forums.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 53 of 55
ceoL8BQF
I too have recently been getting this message as well. Very concerning when using this software at a business that deals with confidential files that cannot be exposed.
Message 54 of 55
Stuart-H
@RajkumarIlanchelian
thanks for the update
Mac Studio M1Max and MacBook Pro M1
Message 55 of 55
HughesTooling
@RajkumarIlanchelian  Seeing this problem again today, is anyone else?
After clearing this dialog
Fusion tells me there's no internet connection but there's a connection.
Running the service utility network diagnostics gives this. Nothing on my PC's changed from yesterday and another PC on the same network is working fine with Fusion.
Mark Hughes
Owner, Hughes Tooling
