self intersection on body
christianiuliano
Message 1 of 8
christianiuliano
I just need to make this into a body to 3d print however I cannot finish the form. Please help the shape needs to stay the same too.
Replies (7)
Message 2 of 8
Phil.E
This can be repaired by using Repair, Make Uniform, Delete, Patch and Stitch.
There are a few areas where the tspline body folds onto itself.
  1. I ended up first using the repair tool on the Utilities menu in Form.
    Then I used Make Uniform, from the same menu, choosing to remove T's.
  2. Then I deleted the face you see above with the red colors on it.
  3. Then the file converted and I could use a Patch / Stitch operation (in the Surface tab) to fill the hole.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
christianiuliano
Do you have the file by any chance? I am still learning the ropes with fusion 360.
Message 4 of 8
Phil.E
Sorry but no. I checked the workflow on a development build and it would not be compatible. If you edit the form, and use the tools I mentioned, it should convert.
@TrippyLighting can you think of any other way to solve this?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 8
christianiuliano
Thanks I will try that
Message 6 of 8
christianiuliano
I got it to work using a patch. Thankyou for your help much appreciated.
Message 7 of 8
TrippyLighting
Of course I can. I told the OP to start from scratch in his other thread with this exact model.
I have done this for a long time and stand by what I said!
Chances are that the NURBS patch layout leads to other modeling problems.
I wish the OP good luck, he'll need it 😉
Message 8 of 8
christianiuliano
It's 3d printable thanks for the help and the video suggestions earlier as well
