Selection tool sometimes not working as intended
I have an intermittent problem with the selection tool. Sometimes, I cannot start a selection on top of a body. In Screencast, it gets registered as a Drag Component event instead even though the box is unchecked in the selection menu (or there is no box). When that happens, the only way I can start a selection in the middle of an object is if I click a face first. Then from there I am able to click and drag to start selecting. But then if I release and press shift + click to add to the selection, the selection is cleared and Screencast records it as a "Drag component" event. Then after I restart Fusion 360, it starts working normally again, where a selection can be started on top of a body. It happens in Model, Patch and Sculpt, with the 3 types of selection tools and regardless of whether history is enabled or not. I am unable to reproduce it reliably. On one instance, which I recorded with NVIDIA Shadowplay, the selection was working fine, then I tabbed out to Firefox to do a Google search and when I came back to Fusion 360, it was not working right anymore. I attached the video. I have recorded several other instances of the selection tool not working. You should be able to find the Screencasts on my profile I think?
2cb85cfd-c630-4777-b430-3ce1dedcd754
