Selection priority given to geometry in other sketches, instead of geometry in the current sketch
evilc
Message 1 of 1
evilc
Create a sketch1, draw a line
Hide sketch1
Create sketch2, draw another line in exactly the same place as sketch1
Unhide sketch1
In sketch2, create another line, click coincident, and click a point on the line in sketch2 (Which also has a line in sketch1 underneath it)
The line in sketch1 is chosen (And projected), instead of just chosing the line in sketch2
And it gets worse!
Now click the first line you drew in sketch2
Hit delete.
Nothing happens, because it selected the line from sketch1
It gets even worse!
Consider this picture where I have done what's described
If you click the projected line near where the mouse cursor is, YOU DONT EVEN SELECT THE PROJECTED LINE!!!
You select the line from sketch1 (The one that you projected)
This is absolutel MADNESS!!!
Replies (0)
