select multiple faces of a body to extrude
andreas.a.philipp
Message 1 of 8
andreas.a.philipp
in the last version of fusion 360 i cannot  select multiple faces of a body to extrude.
Fusion 2.0.20508 arm64 [Native]
Aktiver Plan: Privatanwender
macOS 15.1 (24B83) on Mac14,9
lg Andreas
Replies (7)
Message 2 of 8
g-andresen
Which surface do you want to select?
günther
Message 3 of 8
andreas.a.philipp
more than one 😉
I cannot select another surface. This body is just an example. In none of my designs does it work to select more than one side since the update.
I used to be able to select several sides with (command) and then extrude them all at the same time with (e). If I do that now, only the first one is selected and I cannot add any more (command).
lg Andreas
Message 4 of 8
g-andresen
You can only select faces that are on the same plane.
Please show the process in a screencast
günther
Message 5 of 8
andreas.a.philipp
Message 6 of 8
g-andresen
As I said in my post #4, all profiles must be on the same plane.
günther
Message 7 of 8
andreas.a.philipp
I was sure it worked before.
ok... thank you for your support.
regards Andreas
Message 8 of 8
jeff_strater
"I was sure it worked before"
That has been a limitation in Extrude since the initial version.  However, if you had been using Offset Faces (or Press/Pull, which just calls Offset Faces), you can select multiple non-coplanar faces:
Jeff Strater
Engineering Director
