Segmented bowls rings: Make two driven dimensions equal?
I'm quite new to Fusion, and I'm trying to create a parametric design to help me define dimensions of segments when creating a segmented bowl.
[sidenote:] In woodturning, a segmented bowl is a bowl "machined" out of a stack of rings made up of trapezoidal segments glued together.
Depending on the curvature of the bowl (which is usually designed revolving a spline), defining a good number of segment and segment length and width can be quite tricky.
Here is how I created my sketch (in attach)
- Design a trapeze
- Constrain the 2 parallel lines to be... parallel and space them using user parameter segment_width
- Set the angles of the trapeze to 22,5° (originally, I intended only to create an 8 segments ring..), then in an attempt to make it work, set these angles to driven dimensions
- Draw a construction centerline in the trapeze and set its dimension to user parameter revolve_radius
- Select the 4 lines of my trapeze and create a circular pattern (8 segments originally)
- Make the sides of the trapezes colinear.
This worked quite fine with 8 segments, but I'd like to add a user parameter for that number (segments_number) and have the design adapt to that number. This is the point where things get ugly, with my trapezes getting different angles on each side
I tried to have the angles (which I set to driven dimensions, since their value will change depending on the segments number) equal, but it doesn't seem to be possible to do that.
I suspect there's another way to do that (that doesn't involve any equal driven dimensions...) but I'm stuck there for hours, so if anyone can help, it'll be very appreciated.
