Section analysis only shows slice or full object
thomasa88
thomasa88
I have a strange problem, where section analysis just takes a slice of all bodies instead of cutting them in half. Please see the attached video for the problem in action.
I'm fairly sure that this has worked fine before. It does not matter whether I select a face on a body or a reference plane.
I run Fusion 360 in a Windows 10 VM inside VirtualBox. I usually run with lower graphics, but I turned them up when testing this.
Original design:
Section analysis enabled:
edit. I'm expecting something like this (from the manual):
Settings:
TheCADWhisperer
thomasa88
@TheCADWhispererYes, however, this problem happens with any file that I open, so I think you will find it to be OK.
TheCADWhisperer
What operating system?
What graphics card?
thomasa88
Windows 10, running in a virtual machine in VirtualBox in Ubuntu.
I don't have passthrough for the graphics card, so it is using the emulated "VBoxSVGA" card.
