Search never finds files
marketing5KATC
marketing5KATC
Using the search function at the top is always hit or miss for me. With 'All Data' selected, the search often brings back a 'no object with community ID' even though there are actually several files that include that keyword that I'm searching for.
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @marketing5KATC, thanks for posting.
You can try to follow the steps from this article: How to do a manual reset of the Data Panel in Fusion 360
Maybe that will do the trick for you as a workaround.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
CGBenner
@marketing5KATC
Hello!  Did the suggestion offerred by @Rafal.Chlod work for you, or do you still need help with this?
Chris Benner
Giovanni1983
the suggested workaround did not worked for me
