Screen flickering
Screen flickering
Screen flickering
In the past month i've been back some using Autodesk products, mainly Inventor and Fusion 360, and while working on any of these programs the screen starts flickering madly to the point of almost 0 usability. I have used other autodesk products and the problems show up as well, tried on Maya (it's a shared pc), and older versions never affected my PC like this.
I have tried doing other stuff on the computer and it works fine, from soft work to benchmarking my system to see if under more intense load i can see the problem but until now i have no clue. Anyone have been having this kind of problem?
masa.minohara
Hi @Anonymous,
Thank you for posting! Since the issue is occurring with other software as well, I think the root cause is something on your machine. Could you check if your machine meets the minimum system requirements for Fusion 360? If the machine doesn't meet the system requirements, Fusion 360 may not work as expected.
Also, please try updating the graphics driver to see if that makes a difference.
Please let me know if that helps!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Good Morning and thanks for the reply
I gave a look at all the minimum requirements of the programs that i mentioned on my previous message and i don’t think they should be an issue since they don’t change much from year to year and i have been using all these programs since the 2016 version on my pc.
As for the drivers, all of them according to Windows are updated, and to double check it i uninstaled them again just to be sure. Still having this issue occuring randomly during work sessions.
My specifications are:
-Intel i7 5500u
-NVidia GeForce 920m 2GB
-8GB of DDR3 RAM
It ins’t the best system but for what i am using it for it’s more than enough, since only college work is being done here, and it proved more than capable all these years.
masa.minohara
Hi @Anonymous,
Thank you for your response! I need a few more pieces of information to narrow down what the cause of the problem is-
  • Are you seeing the issue with any designs or with a specific design? Does the issue occur when you start creating a new design?
  • Do you have drivers installed for other peripheral devices such as a tablet or a Spacemouse? Are these up to date as well?
Also, can you post a copy of the DirectX diagnostics from the computer?
  1. Launch %windir%\system32\dxdiag.exe
  2. Select Save All Information
  3. Please reply with the resulting *.TXT file attached
Masanobu Minohara
System Information
Time of this report: 11/22/2017, 10:49:04
Machine name: DESKTOP-NFSJHSE
Machine Id: {534C93E4-9E4E-463B-978A-DF48ECA07AFF}
Operating System: Windows 10 Home 64-bit (10.0, Build 15063) (15063.rs2_release.170317-1834)
Language: Portuguese (Regional Setting: Portuguese)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: X555LJ
BIOS: X555LJ.502
Processor: Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 8192MB RAM
Available OS Memory: 8094MB RAM
Page File: 4305MB used, 5069MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
DxDiag Version: 10.00.15063.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 5500
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_1616&SUBSYS_1A6D1043&REV_09
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 4175 MB
Dedicated Memory: 128 MB
Shared Memory: 4047 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: CMN15B8
Native Mode: 1366 x 768(p) (60.007Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll
Driver File Version: 20.19.0015.4549 (English)
Driver Version: 20.19.15.4549
DDI Version: 12
Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.0
Graphics Preemption: Triangle
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 10/11/2016 00:00:00, 39863888 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-5556-11CF-3662-623AB5C2D935}
Vendor ID: 0x8086
Device ID: 0x1616
SubSys ID: 0x1A6D1043
Revision ID: 0x0009
Driver Strong Name: oem133.inf:5f63e53468b7076c:iBDWM_w10:20.19.15.4549:pci\ven_8086&dev_1616&subsys_1a6d1043
Rank Of Driver: 00D10001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
Card name: NVIDIA GeForce 920M
Manufacturer: NVIDIA
Chip type: GeForce 920M
DAC type: Integrated RAMDAC
Device Type: Render-Only Device
Device Key: Enum\PCI\VEN_10DE&DEV_1299&SUBSYS_1A6D1043&REV_A1
Display Memory: 6068 MB
Dedicated Memory: 2020 MB
Current Mode: Unknown
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvd3dumx.dll,C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvwgf2umx.dll,C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvwgf2umx.dll,C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvwgf2umx.dll
Driver File Version: 21.21.0013.6909 (English)
Driver Version: 21.21.13.6909
DDI Version: 12
Feature Levels: 11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.1
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Discrete
Driver Date/Size: 01/08/2016 00:00:00, 17799424 bytes
WHQL Logo'd: Yes
Device Identifier: Unknown
Vendor ID: 0x10DE
Device ID: 0x1299
Revision ID: 0x00A1
Driver Strong Name: oem62.inf:0f066de32a57efec:Section126:21.21.13.6909:pci\ven_10de&dev_1299&subsys_1a6d1043
Video Accel: Unknown
DXVA2 Modes: Unknown
Deinterlace Caps: n/a
D3D9 Overlay: Unknown
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Altifalantes (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0233&SUBSYS_104319AD&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.7571 (English)
WHQL Logo'd: Yes
Date and Size: 28/07/2015 00:00:00, 4577024 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microfone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Date and Size: 9/19/2017 11:14:54, 4577024 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 1
FriendlyName: USB Camera
SymbolicLink: \\?\usb#vid_0bda&pid_57b5&mi_00#6&4d9b0b7&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Manufacturer: Microsoft
HardwareID: USB\VID_0BDA&PID_57B5&REV_0012&MI_00,USB\VID_0BDA&PID_57B5&MI_00
DriverDesc: Dispositivo de v?deo USB
DriverProvider: Microsoft
DriverVersion: 10.0.15063.447
DriverDateEnglish: 6/21/2006 00:00:00
DriverDateLocalized: 21/06/2006 00:00:00
Service: usbvideo
Class: Image
DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
ProblemCode: No Problem
BusReportedDeviceDesc: USB Camera
Parent: USB\VID_0BDA&PID_57B5\200901010001
DriverProblemDesc: n/a
UpperFilters: n/a
LowerFilters: n/a
Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\AiCharger,\Driver\ACPI,\Driver\usbccgp
ContainerCategory: Imaging
DirectInput Devices
Device Name: Rato
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Teclado
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: ASUS Wireless Radio Control
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Concentrador Raiz USB (USB 3.0)
| Vendor/Product ID: 0x8086, 0x9CB1
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 9/18/2017 23:09:42, 554400 bytes
+-+ Dispositivo USB de Introdu??o de Texto
| | Vendor/Product ID: 0x046D, 0xC077
| | Matching Device ID: USB\Class_03&SubClass_01
| | Service: HidUsb
| | Driver: hidusb.sys, 3/18/2017 20:56:35, 40960 bytes
| | Driver: hidclass.sys, 3/18/2017 20:56:35, 180736 bytes
| | Driver: hidparse.sys, 3/18/2017 20:56:35, 40960 bytes
| +-+ Rato compat?vel com HID
| | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | Service: mouhid
| | | Driver: mouhid.sys, 3/18/2017 20:56:35, 33280 bytes
| | | Driver: mouclass.sys, 3/18/2017 20:56:35, 60320 bytes
Gameport Devices
PS/2 Devices
+ Teclado de PC/AT PS/2 Avan?ado (101/102 Teclas)
| Matching Device ID: *PNP030B
| Service: i8042prt
| Driver: i8042prt.sys, 3/18/2017 20:56:35, 115200 bytes
| Driver: kbdclass.sys, 3/18/2017 20:56:35, 64416 bytes
+ ASUS Touchpad
| Matching Device ID: ACPI\ETD0108
| Upper Filters: ATP
| Service: i8042prt
| Driver: AsusTP.sys, 10/22/2015 15:51:02, 100776 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 263.5 GB
Total Space: 379.7 GB
File System: NTFS
Model: HGST HTS541010A9E680
Drive: 😧
Free Space: 432.9 GB
Total Space: 572.3 GB
File System: NTFS
Drive: E:
Model: TSSTcorp CDDVDW SU-228GB
Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.15063.0000 (Portuguese), 3/18/2017 20:56:25, 160256 bytes
System Devices
Name: NVIDIA GeForce 920M
Device ID: PCI\VEN_10DE&DEV_1299&SUBSYS_1A6D1043&REV_A1\4&AFCB46E&0&00E4
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 21.21.0013.6909 (English), 9/12/2016 20:15:16, 474040 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 8/2/2016 23:05:12, 1341292 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\NvCplSetupInt.exe, 1.00.0005.0000 (Portuguese), 9/12/2016 20:15:30, 97078976 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 8/2/2016 23:04:48, 26629 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (Portuguese), 9/12/2016 20:15:16, 865720 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.6909 (English), 9/12/2016 20:15:18, 429112 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 8/2/2016 23:05:20, 74003 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.6909 (English), 9/12/2016 20:15:20, 467512 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.6909 (English), 9/12/2016 20:15:22, 836152 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.02.0011.0000 (English), 9/12/2016 20:15:26, 219072 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.02.0011.0000 (English), 9/12/2016 20:15:26, 233016 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvlddmkm.sys, 21.21.0013.6909 (English), 9/12/2016 20:15:22, 13754936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvd3dumx.dll, 21.21.0013.6909 (English), 9/12/2016 20:10:00, 17799424 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvwgf2umx.dll, 21.21.0013.6909 (English), 9/12/2016 20:10:02, 20853856 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0013.6909 (English), 9/12/2016 20:15:20, 1021496 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0013.6909 (English), 9/12/2016 20:15:20, 946112 bytes
Driver: C:\Windows\system32\NvIFROpenGL.dll, 21.21.0013.6909 (English), 9/12/2016 20:15:20, 460224 bytes
Driver: C:\Windows\system32\nv-vk64.json, 8/2/2016 23:04:48, 594 bytes
Driver: C:\Windows\system32\nvEncMFTH264.dll, 21.21.0013.6909 (English), 9/12/2016 20:10:00, 835096 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 6.14.0013.6909 (English), 9/12/2016 20:10:00, 438296 bytes
Driver: C:\Windows\system32\nvapi64.dll, 21.21.0013.6909 (English), 9/12/2016 20:10:00, 3912128 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 9/12/2016 20:15:20, 39996984 bytes
Driver: C:\Windows\system32\nvcuda.dll, 6.14.0013.6909 (English), 9/12/2016 20:10:00, 10374488 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.6909 (English), 9/12/2016 20:15:18, 2889272 bytes
Driver: C:\Windows\system32\nvfatbinaryLoader.dll, 9/12/2016 20:10:00, 724376 bytes
Driver: C:\Windows\system32\nvinfo.pb, 8/2/2016 23:05:22, 40296 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 21.21.0013.6909 (English), 9/12/2016 20:15:22, 31704120 bytes
Driver: C:\Windows\system32\nvopencl.dll, 6.14.0013.6909 (English), 9/12/2016 20:10:00, 10840312 bytes
Driver: C:\Windows\system32\nvptxJitCompiler.dll, 9/12/2016 20:10:00, 10864440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvd3dum.dll, 21.21.0013.6909 (English), 9/12/2016 20:10:00, 14767816 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\nvwgf2um.dll, 21.21.0013.6909 (English), 9/12/2016 20:10:02, 18140232 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0013.6909 (English), 9/12/2016 20:15:18, 929848 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0013.6909 (English), 9/12/2016 20:15:20, 869432 bytes
Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 21.21.0013.6909 (English), 9/12/2016 20:15:20, 412216 bytes
Driver: C:\Windows\SysWow64\nv-vk32.json, 8/2/2016 23:04:48, 594 bytes
Driver: C:\Windows\SysWow64\nvEncMFTH264.dll, 21.21.0013.6909 (English), 9/12/2016 20:10:00, 673464 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 6.14.0013.6909 (English), 9/12/2016 20:10:00, 369680 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 21.21.0013.6909 (English), 9/12/2016 20:10:00, 3460824 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 9/12/2016 20:15:20, 35133376 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 6.14.0013.6909 (English), 9/12/2016 20:10:00, 8737976 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0013.6909 (English), 9/12/2016 20:15:18, 2518584 bytes
Driver: C:\Windows\SysWow64\nvfatbinaryLoader.dll, 9/12/2016 20:10:00, 611608 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 21.21.0013.6909 (English), 9/12/2016 20:15:22, 25465280 bytes
Driver: C:\Windows\SysWow64\nvopencl.dll, 6.14.0013.6909 (English), 9/12/2016 20:10:00, 9151448 bytes
Driver: C:\Windows\SysWow64\nvptxJitCompiler.dll, 9/12/2016 20:10:00, 8916512 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nvamwu.inf_amd64_d4715679184092a8\VulkanRT-Installer.exe, 1.00.0011.0001 (English), 9/12/2016 20:15:30, 13622896 bytes
Driver: C:\Windows\system32\nvdispco6436909.dll, 2.00.0045.0004 (English), 9/12/2016 20:15:18, 1956408 bytes
Driver: C:\Windows\system32\nvdispgenco6436909.dll, 2.00.0022.0002 (English), 9/12/2016 20:15:20, 1604152 bytes
Name: Mobile 5th Generation Intel(R) Core(TM) Thermal Management Controller - 9CA4
Device ID: PCI\VEN_8086&DEV_9CA4&SUBSYS_1A6D1043&REV_03\3&11583659&0&FE
Driver: n/a
Name: Bridge de CPU de sistemas PCI padr?o
Device ID: PCI\VEN_8086&DEV_1604&SUBSYS_1A6D1043&REV_09\3&11583659&0&00
Driver: n/a
Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_9CB1&SUBSYS_201F1043&REV_03\3&11583659&0&A0
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.15063.0296 (Portuguese), 4/28/2017 00:59:04, 388000 bytes
Name: Mediatek MT7630E 802.11bgn Wi-Fi Adapter
Device ID: PCI\VEN_14C3&DEV_7630&SUBSYS_E084105B&REV_00\000051D0769AB84000
Driver: C:\Windows\system32\DRIVERS\netr28x.sys, 5.00.0057.0000 (English), 3/18/2017 20:56:23, 2537984 bytes
Name: Mobile 5th Generation Intel(R) Core(TM) PCI Express Root Port #5 - 9C98
Device ID: PCI\VEN_8086&DEV_9C98&SUBSYS_1A6D1043&REV_E3\3&11583659&0&E4
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.15063.0000 (Portuguese), 3/18/2017 20:56:26, 353696 bytes
Name: Mobile 5th Generation Intel(R) Core(TM) PCI Express Root Port #1 - 9C90
Device ID: PCI\VEN_8086&DEV_9C90&SUBSYS_1A6D1043&REV_E3\3&11583659&0&E0
Name: Mobile 5th Generation Intel(R) Core(TM) SMBus Controller - 9CA2
Device ID: PCI\VEN_8086&DEV_9CA2&SUBSYS_1A6D1043&REV_03\3&11583659&0&FB
Driver: n/a
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_200F1043&REV_10\01000000684CE00000
Driver: n/a
Name: Intel(R) 9 Series Chipset Family SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_9C83&SUBSYS_1A6D1043&REV_03\3&11583659&0&FA
Driver: C:\Windows\system32\DRIVERS\iaStorA.sys, 14.06.0000.1029 (English), 8/10/2015 05:17:52, 1462720 bytes
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_9CBA&SUBSYS_1A6D1043&REV_03\3&11583659&0&B0
Driver: C:\Windows\system32\DRIVERS\TeeDriverW8x64.sys, 11.00.0000.1160 (English), 8/6/2015 14:52:54, 184304 bytes
Name: Intel(R) HD Graphics 5500
Device ID: PCI\VEN_8086&DEV_1616&SUBSYS_1A6D1043&REV_09\3&11583659&0&10
Driver: C:\Windows\system32\DRIVERS\igdkmd64.sys, 20.19.0015.4549 (English), 11/30/2016 20:56:00, 7969760 bytes
Driver: C:\Windows\system32\igd10iumd64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:00, 16446360 bytes
Driver: C:\Windows\system32\igd10idpp64.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:54, 312328 bytes
Driver: C:\Windows\system32\igd11dxva64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:02, 33479896 bytes
Driver: C:\Windows\system32\igd12umd64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:08, 4270704 bytes
Driver: C:\Windows\system32\igdumdim64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:28, 39863888 bytes
Driver: C:\Windows\system32\igdail64.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:38, 193032 bytes
Driver: C:\Windows\system32\igfxcmrt64.dll, 5.00.0000.1148 (English), 11/30/2016 20:56:50, 184008 bytes
Driver: C:\Windows\system32\igfx11cmrt64.dll, 5.00.0000.1148 (English), 11/30/2016 20:56:42, 182984 bytes
Driver: C:\Windows\system32\igfxcmjit64.dll, 5.00.0000.1148 (English), 11/30/2016 20:56:18, 1590792 bytes
Driver: C:\Windows\system32\igdde64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:10, 223272 bytes
Driver: C:\Windows\system32\IntelCpHDCPSvc.exe, 1.00.0000.0001 (English), 11/30/2016 20:58:02, 448480 bytes
Driver: C:\Windows\system32\igdusc64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:34, 6696848 bytes
Driver: C:\Windows\system32\igc64.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:44, 15488952 bytes
Driver: C:\Windows\system32\igdmd64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:18, 2393192 bytes
Driver: C:\Windows\SysWow64\igd10iumd32.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:56, 13056568 bytes
Driver: C:\Windows\SysWow64\igd10idpp32.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:50, 297192 bytes
Driver: C:\Windows\SysWow64\igd11dxva32.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:00, 34825520 bytes
Driver: C:\Windows\SysWow64\igd12umd32.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:06, 4239728 bytes
Driver: C:\Windows\SysWow64\igdumdim32.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:24, 38903920 bytes
Driver: C:\Windows\SysWow64\igdail32.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:34, 173576 bytes
Driver: C:\Windows\SysWow64\igdde32.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:08, 181856 bytes
Driver: C:\Windows\SysWow64\igfxcmrt32.dll, 5.00.0000.1148 (English), 11/30/2016 20:56:46, 160296 bytes
Driver: C:\Windows\SysWow64\igfx11cmrt32.dll, 5.00.0000.1148 (English), 11/30/2016 20:56:38, 160296 bytes
Driver: C:\Windows\SysWow64\igfxcmjit32.dll, 5.00.0000.1148 (English), 11/30/2016 20:56:16, 1178632 bytes
Driver: C:\Windows\SysWow64\igdusc32.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:30, 5140496 bytes
Driver: C:\Windows\SysWow64\igc32.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:40, 13483224 bytes
Driver: C:\Windows\SysWow64\igdmd32.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:14, 1858664 bytes
Driver: C:\Windows\SysWow64\iglhcp32.dll, 3.00.0001.0026 (English), 11/30/2016 20:57:02, 205384 bytes
Driver: C:\Windows\SysWow64\iglhsip32.dll, 9.00.0030.9000 (English), 11/30/2016 20:57:10, 1814088 bytes
Driver: C:\Windows\SysWow64\IntelCpHeciSvc.exe, 9.00.0031.9015 (English), 11/30/2016 20:58:06, 301536 bytes
Driver: C:\Windows\system32\iglhxs64.vp, 11/30/2016 00:56:20, 4862 bytes
Driver: C:\Windows\system32\iglhxo64.vp, 11/30/2016 01:56:20, 40343 bytes
Driver: C:\Windows\system32\iglhxc64.vp, 11/30/2016 01:56:20, 40316 bytes
Driver: C:\Windows\system32\iglhxg64.vp, 11/30/2016 01:56:20, 39658 bytes
Driver: C:\Windows\system32\iglhxo64_dev.vp, 11/30/2016 01:56:20, 40931 bytes
Driver: C:\Windows\system32\iglhxc64_dev.vp, 11/30/2016 01:56:20, 41296 bytes
Driver: C:\Windows\system32\iglhxg64_dev.vp, 11/30/2016 01:56:20, 39798 bytes
Driver: C:\Windows\system32\iglhxa64.vp, 11/30/2016 01:56:20, 1125 bytes
Driver: C:\Windows\system32\iglhxa64.cpa, 11/30/2016 01:56:20, 2813952 bytes
Driver: C:\Windows\system32\iglhcp64.dll, 3.00.0001.0026 (English), 11/30/2016 20:57:06, 242184 bytes
Driver: C:\Windows\system32\iglhsip64.dll, 9.00.0030.9000 (English), 11/30/2016 20:57:14, 1816736 bytes
Driver: C:\Windows\system32\cp_resources.bin, 11/30/2016 01:56:14, 511260 bytes
Driver: C:\Windows\system32\difx64.exe, 1.04.0003.0000 (English), 11/30/2016 20:54:44, 175072 bytes
Driver: C:\Windows\system32\igfxDH.dll, 6.15.0010.4549 (English), 11/30/2016 20:56:36, 756744 bytes
Driver: C:\Windows\system32\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:56:38, 84488 bytes
Driver: C:\Windows\system32\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:56:40, 95240 bytes
Driver: C:\Windows\system32\igfxDI.dll, 6.15.0010.4549 (English), 11/30/2016 20:56:44, 399368 bytes
Driver: C:\Windows\system32\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:56:46, 29192 bytes
Driver: C:\Windows\system32\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:56:48, 29192 bytes
Driver: C:\Windows\system32\igfxLHM.dll, 6.15.0010.4549 (English), 11/30/2016 20:57:16, 2142216 bytes
Driver: C:\Windows\system32\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:57:18, 22536 bytes
Driver: C:\Windows\system32\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:57:24, 22536 bytes
Driver: C:\Windows\system32\igfxSDK.exe, 11/30/2016 20:57:32, 1027032 bytes
Driver: C:\Windows\system32\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:57:36, 100872 bytes
Driver: C:\Windows\system32\igfxSDKLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:57:42, 111624 bytes
Driver: C:\Windows\system32\igfxEM.exe, 6.15.0010.4549 (English), 11/30/2016 20:56:54, 354784 bytes
Driver: C:\Windows\system32\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:56:58, 27656 bytes
Driver: C:\Windows\system32\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/30/2016 20:57:00, 27656 bytes
Driver: C:\Windows\system32\GfxUIEx.exe, 6.15.0010.4549 (English), 11/30/2016 20:54:58, 466912 bytes
Driver: C:\Windows\system32\Gfxv4_0.exe, 8.15.0010.4549 (Portuguese), 11/30/2016 20:55:06, 968160 bytes
Driver: C:\Windows\system32\Gfxv4_0.exe.config, 11/30/2016 01:56:14, 935 bytes
Driver: C:\Windows\system32\Gfxv2_0.exe, 8.15.0010.4549 (Portuguese), 11/30/2016 20:55:02, 964576 bytes
Driver: C:\Windows\system32\Gfxv2_0.exe.config, 11/30/2016 01:56:14, 895 bytes
Driver: C:\Windows\system32\GfxResources.dll, 8.15.0010.4549 (Portuguese), 11/30/2016 20:54:54, 5262856 bytes
Driver: C:\Windows\system32\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (Portuguese), 11/30/2016 20:59:02, 705032 bytes
Driver: C:\Windows\system32\igfxCUIServicePS.dll, 11/30/2016 20:56:32, 103432 bytes
Driver: C:\Windows\system32\igfxCUIService.exe, 6.15.0010.4549 (English), 11/30/2016 20:56:28, 373728 bytes
Driver: C:\Windows\system32\igfxCPL.cpl, 11/30/2016 20:56:22, 273416 bytes
Driver: C:\Windows\system32\igfxTray.exe, 11/30/2016 20:57:46, 401888 bytes
Driver: C:\Windows\system32\igfxDTCM.dll, 6.15.0010.4549 (English), 11/30/2016 20:56:50, 254984 bytes
Driver: C:\Windows\system32\igfxHK.exe, 6.15.0010.4549 (English), 11/30/2016 20:57:14, 268768 bytes
Driver: C:\Windows\system32\igfxOSP.dll, 6.15.0010.4549 (English), 11/30/2016 20:57:28, 390152 bytes
Driver: C:\Windows\system32\DPTopologyApp.exe, 8.15.0010.4549 (Portuguese), 11/30/2016 20:54:46, 232416 bytes
Driver: C:\Windows\system32\DPTopologyApp.exe.config, 11/30/2016 01:56:14, 935 bytes
Driver: C:\Windows\system32\DPTopologyAppv2_0.exe, 8.15.0010.4549 (Portuguese), 11/30/2016 20:54:50, 231904 bytes
Driver: C:\Windows\system32\DPTopologyAppv2_0.exe.config, 11/30/2016 01:56:14, 895 bytes
Driver: C:\Windows\system32\igfxext.exe, 6.15.0010.4549 (English), 11/30/2016 20:57:08, 237024 bytes
Driver: C:\Windows\system32\igfxexps.dll, 6.15.0010.4549 (English), 11/30/2016 20:56:56, 55272 bytes
Driver: C:\Windows\system32\ColorImageEnhancement.wmv, 11/30/2016 01:56:14, 375173 bytes
Driver: C:\Windows\system32\ImageStabilization.wmv, 11/30/2016 01:56:20, 403671 bytes
Driver: C:\Windows\system32\FilmModeDetection.wmv, 11/30/2016 01:56:14, 641530 bytes
Driver: C:\Windows\SysWow64\igfxexps32.dll, 6.15.0010.4549 (English), 11/30/2016 20:57:04, 52744 bytes
Driver: C:\Windows\system32\ig8icd64.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:22, 13654536 bytes
Driver: C:\Windows\SysWow64\ig8icd32.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:18, 10329096 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 11/30/2016 01:56:20, 1981 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 11/30/2016 01:56:20, 9788 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 11/30/2016 01:56:20, 34 bytes
Driver: C:\Windows\SysWow64\Intel_OpenCL_ICD32.dll, 2.00.0002.0000 (English), 11/30/2016 20:58:54, 103944 bytes
Driver: C:\Windows\SysWow64\IntelOpenCL32.dll, 20.19.0015.4549 (English), 11/30/2016 20:58:10, 318472 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:56, 373256 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:48, 7126536 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:34, 1408520 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:26, 522760 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 11/30/2016 01:56:20, 1223604 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 11/30/2016 01:56:20, 296664 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 11/30/2016 01:56:20, 389300 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 11/30/2016 01:56:20, 1157132 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 11/30/2016 01:56:20, 287436 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 11/30/2016 01:56:20, 389180 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 11/30/2016 01:56:20, 785172 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 11/30/2016 01:56:20, 249992 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 11/30/2016 01:56:20, 350952 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:20, 242696 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 3.04.0000.0000 (English), 11/30/2016 21:01:52, 5022728 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 3.04.0000.0000 (English), 11/30/2016 21:01:40, 5360136 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 3.04.0000.0000 (English), 11/30/2016 21:01:54, 5238280 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.02.2014.0601 (Portuguese), 11/30/2016 21:01:14, 208544 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.02.2014.0601 (Portuguese), 11/30/2016 21:01:06, 360104 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb_preview.dll, 4.02.2013.1002 (), 11/30/2016 21:01:24, 356008 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\common\clbltfnshared.rtl, 11/30/2016 01:56:20, 1026520 bytes
Driver: C:\Windows\system32\Intel_OpenCL_ICD64.dll, 2.00.0002.0000 (English), 11/30/2016 20:59:00, 99848 bytes
Driver: C:\Windows\system32\IntelOpenCL64.dll, 20.19.0015.4549 (English), 11/30/2016 20:58:14, 416264 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 5.02.0000.10094 (English), 11/30/2016 21:01:00, 428552 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:50, 9629192 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:38, 1628168 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:32, 669192 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 11/30/2016 01:56:20, 1226660 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 11/30/2016 01:56:20, 358288 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 11/30/2016 01:56:20, 402580 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 11/30/2016 01:56:20, 1159784 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 11/30/2016 01:56:20, 347104 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 11/30/2016 01:56:20, 402468 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 11/30/2016 01:56:20, 788292 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 11/30/2016 01:56:20, 294032 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 11/30/2016 01:56:20, 364424 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 5.02.0000.10094 (English), 11/30/2016 21:00:24, 267784 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_h8.dll, 3.04.0000.0000 (English), 11/30/2016 21:01:46, 5234184 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_e9.dll, 3.04.0000.0000 (English), 11/30/2016 21:01:34, 5744648 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_l9.dll, 3.04.0000.0000 (English), 11/30/2016 21:01:48, 5627400 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.02.2014.0601 (Portuguese), 11/30/2016 21:01:20, 248488 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.02.2014.0601 (Portuguese), 11/30/2016 21:01:12, 438440 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb_preview.dll, 4.02.2013.1002 (), 11/30/2016 21:01:30, 433824 bytes
Driver: C:\Windows\SysWow64\igdbcl32.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:42, 388616 bytes
Driver: C:\Windows\SysWow64\igdrcl32.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:12, 4364296 bytes
Driver: C:\Windows\SysWow64\common_clang32.dll, 4.00.0000.0000 (English), 11/30/2016 20:54:36, 19861512 bytes
Driver: C:\Windows\SysWow64\igdmcl32.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:06, 3971592 bytes
Driver: C:\Windows\SysWow64\igdfcl32.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:52, 225288 bytes
Driver: C:\Windows\system32\igdbcl64.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:46, 439304 bytes
Driver: C:\Windows\system32\igdrcl64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:14, 4928008 bytes
Driver: C:\Windows\system32\common_clang64.dll, 4.00.0000.0000 (English), 11/30/2016 20:54:40, 29101576 bytes
Driver: C:\Windows\system32\igdmcl64.dll, 20.19.0015.4549 (English), 11/30/2016 20:56:10, 5688840 bytes
Driver: C:\Windows\system32\igdfcl64.dll, 20.19.0015.4549 (English), 11/30/2016 20:55:56, 266248 bytes
Driver: C:\Windows\system32\igdclbif.bin, 11/30/2016 01:56:18, 5799386 bytes
Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 7.16.0010.0020 (English), 11/30/2016 20:57:16, 8872616 bytes
Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.16.0010.0020 (English), 11/30/2016 20:59:04, 4741336 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 7.16.0010.0020 (English), 11/30/2016 20:57:24, 1457160 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 7.16.0010.0020 (English), 11/30/2016 20:59:30, 1350368 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_32.dll, 7.16.0010.0020 (English), 11/30/2016 21:00:02, 1358552 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_32.dll, 7.16.0010.0020 (English), 11/30/2016 21:00:08, 1358560 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 7.16.0010.0020 (English), 11/30/2016 20:57:30, 1471464 bytes
Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 11/30/2016 00:56:14, 63761 bytes
Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 11/30/2016 00:56:14, 62217 bytes
Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 11/30/2016 01:56:14, 846855 bytes
Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 11/30/2016 00:56:14, 993 bytes
Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 11/30/2016 00:56:14, 21523 bytes
Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 11/30/2016 00:56:20, 57541 bytes
Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 7.16.0010.0020 (English), 11/30/2016 20:57:20, 9318408 bytes
Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 1.16.0010.0020 (English), 11/30/2016 20:59:08, 4919520 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 7.16.0010.0020 (English), 11/30/2016 20:57:28, 1810920 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 7.16.0010.0020 (English), 11/30/2016 20:59:36, 1677528 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_64.dll, 7.16.0010.0020 (English), 11/30/2016 21:00:06, 1686240 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_64.dll, 7.16.0010.0020 (English), 11/30/2016 21:00:10, 1687264 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_64.dll, 7.16.0010.0020 (English), 11/30/2016 20:57:34, 1836776 bytes
Driver: C:\Program Files\Intel\Media SDK\h265e_64.vp, 11/30/2016 00:56:14, 13485 bytes
Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 11/30/2016 00:56:14, 12873 bytes
Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 11/30/2016 01:56:14, 1519616 bytes
Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 11/30/2016 00:56:14, 993 bytes
Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 11/30/2016 00:56:14, 21523 bytes
Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 11/30/2016 00:56:20, 12365 bytes
Driver: C:\Windows\system32\igfxCoIn_v4549.dll, 1.03.0023.0000 (English), 11/30/2016 21:57:52, 220168 bytes
Driver: C:\Windows\system32\DisplayAudiox64.cab, 11/30/2016 00:56:14, 831685 bytes
Name: Mobile 5th Generation Intel(R) Core(TM) PCI Express Root Port #4 - 9C96
Device ID: PCI\VEN_8086&DEV_9C96&SUBSYS_1A6D1043&REV_E3\3&11583659&0&E3
Name: Intel(R) Dynamic Platform and Thermal Framework Processor Participant
Device ID: PCI\VEN_8086&DEV_1603&SUBSYS_1A6D1043&REV_09\3&11583659&0&20
Driver: C:\Windows\system32\DRIVERS\dptf_cpu.sys, 8.01.10603.0192 (English), 8/12/2015 23:54:46, 53752 bytes
Driver: C:\Windows\system32\DRIVERS\WdfCoInstaller01011.dll, 1.11.9200.16384 (Portuguese), 8/12/2015 23:54:46, 1807544 bytes
Name: Mobile 5th Generation Intel(R) Core(TM) PCI Express Root Port #3 - 9C94
Device ID: PCI\VEN_8086&DEV_9C94&SUBSYS_1A6D1043&REV_E3\3&11583659&0&E2
Name: Controlador de High Definition Audio
Device ID: PCI\VEN_8086&DEV_9CA0&SUBSYS_19AD1043&REV_03\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.15063.0447 (English), 6/20/2017 05:12:02, 86528 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.15063.0000 (English), 3/18/2017 20:56:20, 97280 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.15063.0000 (English), 3/18/2017 20:56:20, 373248 bytes
Name: Mobile 5th Generation Intel(R) Core(TM) Premium SKU LPC Controller - 9CC3
Device ID: PCI\VEN_8086&DEV_9CC3&SUBSYS_1A6D1043&REV_03\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.15063.0000 (English), 3/18/2017 20:56:26, 19352 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.15063.0000
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.15063.0000
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.15063.0000
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.15063.0000
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.15063.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.15063.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.15063.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.15063.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.15063.0000
DV Muxer,0x00400000,0,0,qdv.dll,10.00.15063.0000
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.15063.0674
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.15063.0502
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.15063.0674
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.15063.0674
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.15063.0000
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.15063.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.15063.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.15063.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.15063.0674
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.15063.0674
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.15063.0674
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.15063.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.15063.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.15063.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.15063.0000
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.15063.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.15063.0674
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.15063.0674
DV Splitter,0x00600000,1,2,qdv.dll,10.00.15063.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.15063.0674
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.15063.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.15063.0674
Video Renderer,0x00800001,1,0,quartz.dll,10.00.15063.0674
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.15063.0000
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.15063.0674
Video Renderer,0x00400000,1,0,quartz.dll,10.00.15063.0674
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.15063.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.15063.0502
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.15063.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.15063.0000
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.15063.0000
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.15063.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.15063.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.15063.0000
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.15063.0000
Null Renderer,0x00200000,1,0,qedit.dll,10.00.15063.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.15063.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.15063.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.15063.0000
Smart Tee,0x00200000,1,2,qcap.dll,10.00.15063.0000
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.15063.0674
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.15063.0674
Wave Parser,0x00400000,1,1,quartz.dll,10.00.15063.0674
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.15063.0674
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.15063.0674
File stream renderer,0x00400000,1,1,quartz.dll,10.00.15063.0674
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.15063.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.15063.0000
AVI Mux,0x00200000,1,0,qcap.dll,10.00.15063.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.15063.0674
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.15063.0674
File Source (URL),0x00400000,0,1,quartz.dll,10.00.15063.0674
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.15063.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.15063.0000
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.15063.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.15063.0674
WDM Streaming Tee/Splitter Devices:
Conversor Tee/Sink-to-Sink,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.15063.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.15063.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.15063.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.15063.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.15063.0674
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.15063.0000
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.15063.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.15063.0674
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.15063.0674
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.15063.0674
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.15063.0674
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.15063.0674
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.15063.0674
Audio Capture Sources:
Microfone (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.15063.0000
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.15063.0000
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.15063.0000
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.15063.0000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.15063.0674
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.15063.0674
WDM Streaming Capture Devices:
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
USB Camera,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.15063.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.15063.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.15063.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.15063.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.15063.0000
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.15063.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.15063.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.15063.0000
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.15063.0000
PTFilter,0x00200000,0,0,EncDec.dll,10.00.15063.0000
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.15063.0000
WDM Streaming Communication Transforms:
Audio Renderers:
Altifalantes (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.15063.0674
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.15063.0674
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.15063.0674
DirectSound: Altifalantes (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.15063.0674
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
Video Decoders:
Intel? Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 7.16.0010.0020
Intel? Hardware VP8 Decoder MFT, {6D856398-834E-4A89-8EE5-071BB3F58BE4}, 0x6, mfx_mft_vp8vd_64.dll, 7.16.0010.0020
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.15063.0000
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.15063.0000
Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.15063.0000
Intel? Hardware VP8 Sync Decoder MFT, {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}, 0x1, mfx_mft_vp8vd_64.dll, 7.16.0010.0020
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.15063.0000
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.15063.0000
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.15063.0000
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.15063.0000
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.15063.0138
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.15063.0000
Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.15063.0000
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.15063.0000
Video Encoders:
Intel? Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 7.16.0010.0020
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264.dll, 21.21.0013.6909
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.15063.0000
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.15063.0000
Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.15063.0675
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.15063.0000
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.15063.0000
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.15063.0000
H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.15063.0000
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.15063.0000
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.15063.0000
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.15063.0250
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.15063.0000
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.15063.0000
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.15063.0608
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.15063.0502
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.15063.0000
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.15063.0000
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.15063.0447
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.15063.0608
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.15063.0608
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.15063.0000
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.15063.0000
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.15063.0000
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.15063.0447
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.15063.0000
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.15063.0608
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.15063.0608
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.15063.0000
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.15063.0000
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.15063.0608
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.15063.0000
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.15063.0000
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.15063.0000
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.15063.0608
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.15063.0000
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.15063.0000
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.15063.0000
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.15063.0000
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.15063.0000
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.15063.0000
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.15063.0000
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.15063.0000
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.15063.0000
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.15063.0000
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.15063.0000
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.15063.0000
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
, , [, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
, , [, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Registo de falhas 0x888_netr28x!LoadAndesFW, tipo 0
Nome do Evento: BlueScreen
Resposta: N?o dispon?vel
ID do CAB: 5d7e6857-f002-4643-9c2c-747f85c9230a
Assinatura do problema:
P1: 888
P2: 0
P3: 0
P4: 0
P5: 0
P6: 10_0_15063
P7: 0_0
P8: 768_1
P9:
P10:
Ficheiros anexados:
\\?\C:\Windows\Minidump\112117-47828-01.dmp
\\?\C:\Windows\TEMP\WER-133046-0.sysdata.xml
\\?\C:\Windows\MEMORY.DMP
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERE9B5.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WEREA61.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WEREA91.tmp.txt
Estes ficheiros podem estar dispon?veis aqui:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_888_be1f42524164d91e111ab62d709a49c28ec16db7_00000000_cab_18bce0f6
S?mbolo de an?lise:
A procurar novamente solu??o: 0
ID do Relat?rio: 5ef6c82e-ce6a-4ed6-b86f-1ee1699968ac
Estado do Relat?rio: 268435456
Registo com hash:
+++ WER1 +++:
Registo de falhas , tipo 0
ID do CAB: 0
P1: 888
P2: 0
P3: 0
P4: 0
P5: 0
P6: 10_0_15063
P7: 0_0
P8: 768_1
P9:
P10:
Ficheiros anexados:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_888_be1f42524164d91e111ab62d709a49c28ec16db7_00000000_cab_03a3eaaf
S?mbolo de an?lise:
Estado do Relat?rio: 4
Registo com hash:
+++ WER2 +++:
Registo de falhas 129400675292, tipo 5
Nome do Evento: RADAR_PRE_LEAK_64
ID do CAB: 0
P1: Inventor.exe
P2: 22.0.11200.0
P3: 10.0.15063.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
Ficheiros anexados:
\\?\C:\Users\joaov\AppData\Local\Temp\RDRD039.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD04A.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD080.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD0BF.tmp.txt
S?mbolo de an?lise:
ID do Relat?rio: d19128f4-af19-40a8-9181-e24b714f88fb
Registo com hash: 57b4669fdce03bfde13779b397ab8597
+++ WER3 +++:
Registo de falhas 1885336912380764821, tipo 5
Nome do Evento: MoAppCrash
ID do CAB: 0
P1: microsoft.windowscommunicationsapps_17.8700.40675.0_x64__8wekyb3d8bbwe
P2: praid:ppleae38af2e007f4358a809ac99a64a67c1
P3: 16.0.8700.4067
P4: 5a0ce970
P5: Mso20Imm.dll
P6: 16.0.8625.1004
P7: 59de0fe8
P8: 010a27e0
P9: 00000000001411f3
P10:
Ficheiros anexados:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC04A.tmp.mdmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCB09.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCB18.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCB76.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_microsoft.window_4e44d79b7dc7ce5678e9d288d254bd7c33b5184_1df68f74_12d0d73d
S?mbolo de an?lise:
ID do Relat?rio: 30e6e63f-d2ea-4825-bed9-bdac906f8d25
Registo com hash: 4cb82313821be793da2a0feed0632295
+++ WER4 +++:
Nome do Evento: AppHangB1
ID do CAB: 0
P1: Fusion360.exe
P2: 3706.2.0.0
P3: 59f0b82e
P4: 4023
P5: 134217728
P6:
P7:
P8:
P9:
P10:
Ficheiros anexados:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERFA50.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERFA62.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERFA91.tmp.txt
\\?\C:\Users\joaov\AppData\Local\Temp\WERCB0.tmp.appcompat.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppHang_Fusion360.exe_5264a334ad17ed1e2efa91a87f11d1ab2b5f2737_72c92af1_22bd1971
S?mbolo de an?lise:
ID do Relat?rio: c8964eab-37cb-4d9e-9b63-d8b42f4936c0
Estado do Relat?rio: 97
Registo com hash:
+++ WER5 +++:
Nome do Evento: AppHangTransient
ID do CAB: 0
P1: Fusion360.exe
P2: 3706.2.0.0
P3: 59f0b82e
P4: unknown
P5: unknown
P6: unknown
P7: unknown
P8:
P9:
P10:
Ficheiros anexados:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER48D7.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER48E7.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4926.tmp.txt
S?mbolo de an?lise:
ID do Relat?rio: f67d61f2-fcb0-4c43-ad65-7d639f93455d
Estado do Relat?rio: 2049
Registo com hash:
+++ WER6 +++:
Registo de falhas 129603752804, tipo 5
ID do CAB: 0
P1: Fusion360.exe
P2: 3706.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
Ficheiros anexados:
\\?\C:\Users\joaov\AppData\Local\Temp\RDR3086.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER30A7.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER311D.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER314C.tmp.txt
S?mbolo de an?lise:
ID do Relat?rio: d6871228-c00b-4eb4-ae01-ea7de3e76078
Registo com hash: 48bc9271d1a6383738f1c2c9fcccc6c1
+++ WER7 +++:
Registo de falhas 129598260150, tipo 5
ID do CAB: 0
P1: opera.exe
P2: 48.0.2685.52
P4:
P5:
P6:
P7:
P8:
P9:
P10:
Ficheiros anexados:
\\?\C:\Users\joaov\AppData\Local\Temp\RDR3C11.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3C22.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3C5C.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3CDA.tmp.txt
S?mbolo de an?lise:
ID do Relat?rio: f56b3c6f-45c2-4327-bca9-0e443ae16bed
Registo com hash: a1f81c6c98897a2af9450cb4de583870
+++ WER8 +++:
Registo de falhas 1977458303045152439, tipo 5
ID do CAB: 0
P1: aces.exe
P2: 1.73.1.81
P4:
P5:
P6:
P7:
P8:
P9:
P10:
Ficheiros anexados:
\\?\C:\Users\joaov\AppData\Local\Temp\RDR2207.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2237.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER23CA.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2448.tmp.txt
S?mbolo de an?lise:
ID do Relat?rio: af5247b1-8bed-4c44-ac7b-05109f348833
Registo com hash: 2b467a98cbcd78ac8b7157d97f272eb7
+++ WER9 +++:
Registo de falhas 133569131850, tipo 5
Nome do Evento: MoAppHang
ID do CAB: 0
P1: Microsoft.Windows.Photos_2017.39091.16340.0_x64__8wekyb3d8bbwe
P2: praid:App
P3: 2017.39091.16340.0
P4: 59f7fdbc
P5: 094b
P6: 2097152
P7:
P8:
P9:
P10:
Ficheiros anexados:
\\?\C:\Users\joaov\AppData\Local\Packages\Microsoft.Windows.Photos_8wekyb3d8bbwe\LocalState\PhotosAppTracing.etl
triagedump.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC30E.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC32D.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC34E.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppHang_Microsoft.Window_641f8eb27eb3d1012a0721e21f817121f109a73_3132cb02_283accf1
S?mbolo de an?lise:
ID do Relat?rio: 6fa64277-f079-421d-8d7c-8ad7180915cc
Registo com hash: a0bb21bcadc96747bf465641ffcca78c
masa.minohara
Hi @Anonymous,
Thank you for posting the information! I'll look for clues to why the issue is occurring and let you know as soon as I find anything.
In the meantime, could you try the steps described in this article to see if that helps?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
