Scale is not correct on an exported PDF drawing.
I_K_H_
I_K_H_
When I export a drawing in PDF then print on sheet size B (or any matching sheet size). I check it with the scale ruler and it does not match. It seems like everything shrinks slightly. Is their a solution to this?
mohammed.aliTDPXK
Hello @I_K_H_ ,
what is the shrink percentage you are seeing ?
Suppose you have a 100 mm length and you have used a 1:1 scale and measure with a ruler what is the % it is shrinking?
There can be slight shrink based on the printer may be.
Md Adam Ali
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
g-andresen
You must deactivate the “Fit to paper” option in the PDF print menu under Scaling and activate “real size”.
günther
