Saving to STL
Saving to STL
wo009b0742
Saving to STL
wo009b0742
I have noticed recently that saving a design to STL to print is taking several minutes and I can only export once. I have to exit the software and then open it, load my design to then export another part of my design. Is there a fix for this behaviour?
jhackney1972
You should use the Save as Mesh command instead of Export.  It is much more efficient and offers some advantages.  Select your Body in the Browser, right mouse click and select the command.  Set you desired parameters in the dialog box (not shown) and save your file.
John Hackney, Retired
Phil.E
There is a new build of Fusion that should have a fix for this. Can you please update Fusion to build 2.0.18220, which was released yesterday, and let us know if the issue is solved for you?
How to update Fusion
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
