Save DXF sketch as single line/arc
aaronhenton
aaronhenton
Is it possible to save the DXF sketch in fusion 360 as a single or more simple line/arc rather than multiple points?
When the DXf file is used on a CNC cutting machine it is altering the cutting speed where it is following the multiple point locations rather than following a single arc?
HughesTooling
Can you attach sample files? Really need an f3d and DXF of the same part. If the sketch contains arcs\lines then the DXF should also be arcs\lines.
Mark
Mark Hughes
Owner, Hughes Tooling
