Save as STL options greyed out
Hi, long time listener, first time caller.
There's a bug in Fusion on the "Save As STL" menu.
If I am trying to save multiple bodies as STL, I have the option of exporting them as one file or as one file per body. If I choose to export them as one file, I have the option of exporting them to a file directory or straight into my 3D Print Utility. That works great. If I choose to export them as one file per body, the option to export directly into my 3D Print Utility is greyed out. That also makes sense. However, if I leave the menu with the structure set as "one file per body", Fusion remembers that for the next time, even if I am trying to save one body as an STL.
When I try to export one body as an STL, the structure menu is greyed out, but it is stuck on my previous selection of "one file per body," which also means "send to 3D print utility" is greyed out, and I am forced to save to disk. The only way to fix this is to go back and export multiple bodies, select "one file" as a structure, and then exit the menu. Only then will the menu allow me to export directly to a 3D print utility.
Options when exporting multiple bodies.
Send to 3D print utility greyed out if I select one file per body.
The result of trying to export a single body after exporting multiple bodies to a directory. You can see "Structure" is still set to "one file per body," but I can't change it, which then locks me out of "send to 3D print utility."
