Save as Mesh > One File Per Body yields way too many files
dtiner12
dtiner12
I have a file with some nested components. When I right click a component do Save as Mesh with the one file per body option, I am getting multiple files per body. I haven't figured out precisely how many extraneous bodies there are, but e.g. for one component that has 8 bolts, I am getting 64 files, so it may be a squared relationship. It may not be as straightforward as the square of the number of bodies as I think the severally-nested component layers factor in.
I think my component has 57 bodies, but I get 1369 files. I just made a test file with 5 bodies that yields 25 files. I'm looking into writing a bash script to delete the extraneous files for now, but this is very unexpected behavior.
jhackney1972
Take a look at this Forum post.  It talks about a Fusion Add-in I think will do the trick for you.  Please read to the end of it as the author talks about various revisions and other details.
John Hackney, Retired
dtiner12
That plugin works with their One File Per Body In Occurrence option. Thanks!
jhackney1972
Glad it was what you needed.  Make sure you select the solution post and then select "Accept as Solution" so others can also find the answer to a similar question.
