Rotating to the point?
Hello.
I need to rotate body same way i did it with this line but it isn't rotating to the point.
Can someone please give it a look and tell if it is normal behaviour or sholud it rotate to the point?
Or is there some other way of doing it?
Thanks!
#modell
TheCADWhisperer
You should fully define each sketch as you go.
Don't rotate or move line - sketch and snap to where you want the lines.
jhackney1972
Please share you model with the forum users so they can troubleshoot your issue.  Open model, go to File, Export and then save to your hard drive.  The attach it to a forum post using the Attachments section.
John Hackney, Retired
