Rotated bodies are missing a hole on the bottom plane
ptr727
ptr727
I am trying to create a stevenson screen for a weather station.
I am trying to create discs that will push into each other.
I just created a basic layout, but I'm having trouble getting the duplicated posts to render with a hole in all but the original body.
I don't know if it is a rendering artifact, or if I cut the post body incorrectly, or if my rotated copies are wrong.
Any help appreciated.
TheCADWhisperer
I don't see where you patterned the hole feature (Extrude 8), but I have to wonder if this is what you really really want.
The hole in the Revolve Dome body would be too small for the posts Stand bodies.  See Attached my interpretation of what I think you really want (real world logic)...
ptr727
Thank you, I mistakenly thought the body with a cut would also cut through when patterned.
And yes, I need to adjust the dimensions to fit, was just getting stuck on the holes not showing up.
Thank you.
