Rotate view - reference selectin is missing
chrispDHUUA
Message 1 of 11
chrispDHUUA
The reference selection is missing when trying to rotate a drawing view.
Did this move, change, or is it no longer available?
Replies (10)
Message 2 of 11
jhackney1972
It is still there.
John Hackney, Retired
Message 3 of 11
chrispDHUUA
I have figured out a solution. Here's what you need to do:
  1. Select the desired view.
  2. Locate the origin point and click on it to select it.
  3. Then, reselect the origin point.
  4. Once you have reselected the origin, you should see an option to select the other endpoint.
  5. Click on the other endpoint to select it.
  6. With the other endpoint selected, you can now rotate the view along that line to square it.
By following these steps, I was able to adjust and square the view as needed.
For some reason I thought a special reference angle option would appear.
Message 4 of 11
chrispDHUUA
D'oh!  Nevermind, I was was wrong.  I was just reselecting the origin.  It looks like the reference angle command it missing.
Message 5 of 11
chrispDHUUA
Message 6 of 11
adammX4R8K
Observer
Observer
I am having same problem. Reference select button was there this morning but has now disappeared.
Message 7 of 11
adammX4R8K
Observer
Observer
The Reference select option is not present when I try to rotate a drawing view.
Message 8 of 11
GeoffPacker7777
I agree, the latest version seems to have removed the ability to select a reference to rotate a drawing view. Mr Fusion can we reinstate it please, thanks
Message 9 of 11
HughesTooling
I have not update one of my PCs and can confirm the reference option is missing in the latest version.
Here's a screenshot from the PC without the latest update. @ClintBrown3D Has this been logged?
Mark Hughes
Owner, Hughes Tooling
Message 10 of 11
ClintBrown3D
Hi All
This has been logged and already been worked on, the fix will be rolled out under the next hotfix build.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 11 of 11
GeoffPacker7777
excellent, thanks Clint
