Rotate snaps to a plane unexpectedly.
jacksted
Observer Observer
jacksted
Observer
Observer
When I rotate from the front plane towards the left plane the object unexpectedly snape to the right plane.
jhackney1972
In order to understand your issue you need to attach an animated GIF or a video showing your issue.
John Hackney, Retired
jacksted
Observer
Observer
Good Morning,
Here is a short video of the issue. Happens no matter what plane you start with. Only happens when you move the mouse from left to right. Also happens in the multiplane view.
Thank, Jack
jhackney1972
This is a known problem for some resolution monitors.  You can try and reset your monitor to its default resolution to take care of the issue.  A better method of rotation is to use your mouse.  With your Pan, Zoom, Orbit settings set to Fusion 360, you can hold the Shift key on the keyboard and the middle mouse button to rotate very effectively.  Also the Orbit command is a good tool.  In the attached GIF, I am using the Preference shown with the Shift key and Mouse.
jacksted
Observer
Observer
Thanks John, I tried all of the display settings in fusion and windows and nothing made any difference. The alternative way of rotating is very helpful. Thanks again, Jack
