Rotate Sketch Axis
Rotate Sketch Axis
ivar.cashin.eriksson
Rotate Sketch Axis
Hi, I want to make a sketch with a few rectangles in the xy-plane. I don't however want the rectangles to be parallell with the axes rather I want them rotated 30 degrees around the z-axis to line up with a part in my model. Now I can draw the sketch parallell to the xy-axes and rotate it after but this makes it more difficult to make use of the features in the bodies of the model.
So to clarify:
How do I define a sketch plane in the xy-plane to have its coordinate system and grid NOT line up with the xy-axes?
jeff_strater
3-point rectangle is the ticket:
Jeff Strater
Engineering Director
MoshiurRashid
Hi
Thanks for posting. Follow these steps.
1. Create a rectangle by "3 point rectangle" from the drop down.
2. Create a rectangle by placing 1 point on the origin and others as your wish.
3. Create a line with the origin and use "Dimension" command to place dimension of 30 deg.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
