Retopology of a 3d-Reference Polygon Mesh
stefan8FSTS
stefan8FSTS
I plan to convert a polygonal mesh into CAD.
How to do this:
for retopology in Polygon Modeller I can make Splines or Polys that
snap automaticly to the reference mesh.
I would like to do similar thinks. But how?
Do Fusion have an Snap function?
Thanks a lot!
I
dsouzasujay
Hi @stefan8FSTS ,
If you want to convert a mesh body to BRep body
  • With Triangular mesh facets, convert to Brep
    1. When a mesh body has triangular facets
    2. Convert "Mesh to BRep"
    3. Mesh to Brep
  • With Triangular mesh facets, convert to Brep from Mesh section
    • When a mesh body has triangular facets
    • "Create Mesh Section"
    • From Mesh section create 2D sketch
    • Create solid body from extrude
    • Mesh Section & BRep
  • With Quad mesh facets, convert to Brep
    1. Import the Quad mesh file to Fusion 360
    2. Go to sculpt
    3. Convert Mesh to TSplines
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
stefan8FSTS
Thank you very much!
