Reset of custom 3d printer not possible
JuergenL4QU5
JuergenL4QU5
After switching my Hardware I reinstalled Fusion and my slicer "simplify 3d" software.
Simplify 3d got a new version and folder.
When I now try to send to my Custom 3D Printer application the OK Button will not be enabled.
I've assumed that somewhere the old path is stored and I wanted to set the application again,
but when I press on the folder icon nothing happens.
Is there any other way to "reset" the custom application ?
Br Jürgen
HughesTooling
That should work, I just tried it and it works for me. Does the save dialog open correctly if you use Export from the file menu the select the folder from the export dialog?
Mark
Mark Hughes
Owner, Hughes Tooling
JuergenL4QU5
Wow , good guess.
No this dialog also does not show up anymore .
HughesTooling
Think I know the problem. Have you saved to a drive or folder that's no longer available? Read this thread from this post on for a solution. If it fixed the problem can you come back and describe what you've done to make the drive\folder unavailable please.
Thanks Mark
Mark Hughes
JuergenL4QU5
Thanks a lot !
That solved both problems.
There was a temp network folder that I've not yet mapped on the new computer.
You saved my day !
